Web Weather => Weather Website PHP/AJAX scripting => Topic started by: Forever on March 17, 2023, 07:42:46 PM
Is anyone still using the WxSimCSV script and know how to fix the deprecated errors?
http://www.weathercat.net/wxsimcsv.php
PHP Deprecated: Function date_sunrise() is deprecated in C:\inetpub\weathercat\wxsimcsv\index.php on line 158
PHP Deprecated: Function date_sunset() is deprecated in C:\inetpub\weathercat\wxsimcsv\index.php on line 159
PHP Deprecated: Function date_sunrise() is deprecated in C:\inetpub\weathercat\wxsimcsv\index.php on line 160
PHP Deprecated: Function date_sunset() is deprecated in C:\inetpub\weathercat\wxsimcsv\index.php on line 161
PHP Deprecated: Implicit conversion from float 17.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 302
PHP Deprecated: Implicit conversion from float 17.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 18.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 19.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 20.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 21.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 22.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 23.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 24.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 1.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 2.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 3.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 4.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 5.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 6.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 7.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 8.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 9.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 10.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 11.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 12.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 13.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 14.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 15.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
PHP Deprecated: Implicit conversion from float 16.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 317
Post the script, and I'll take a look.
Generally, instead of using date_sunrise/date_sunset, you have to switch to date_sun_info() instead. And use the returned array with 'sunrise' and 'sunset' to address the values. Like $now = time();
$sun = date_sun_info($now, $SITE['latitude' ], $SITE["longitude"]);
$da = $sun["civil_twilight_begin"];
$sr = $sun["sunrise"];
$st = $sun["transit"];
$ss = $sun["sunset"];
$du = $sun["civil_twilight_end"];
Fixing the implicit conversion usually means adding (float) in front of the variable/expression to cast it to float explicitly.
Thanks for look at this for me. I tried to attach the file but it may be too big?
Here is a link to the file.
http://www.weathercat.net/wssimcsv.zip
So, I did download the .zip. Added just one line and get no errata on PHP 8.2:
Change wxsimcsv/index.php // Explode into array $data
for ($i = 0; $i < 2; $i++) {$data[$i] = explode($sep, $csv[$i]);}
to // Explode into array $data
$data = array();
I'm still getting the deprecated errors. I know I can turn this off in my PHP.ini but was try to get this fixed before it stops working in a future version of PHP. Would it be hard to fix them?
Ok.. change wxsimcsv/index.php from
$srise = date_sunrise(time(), SUNFUNCS_RET_STRING, $lat, $long, 90, $gmtoffset);
$sset = date_sunset(time(), SUNFUNCS_RET_STRING, $lat, $long, 90, $gmtoffset);
$sunrise = round(date_sunrise(time(), SUNFUNCS_RET_DOUBLE, $lat, $long, 90, $gmtoffset));
$sunset = round(date_sunset(time(), SUNFUNCS_RET_DOUBLE, $lat, $long, 90, $gmtoffset));
to $sun = date_sun_info(time(), $lat, $long);
$srise = date('H:i',$sun["sunrise"]);
$sset = date('H:i',$sun["sunset"]);
$sunrise = (integer)date('H',$sun["sunrise"]);
$sunset = (integer)date('H',$sun["sunset"]);
and in wxsimcsv/usersettings.php change $dst = date("I"); //Set Daylight Savings Time
to $dst = (integer)date("I"); //Set Daylight Savings Time
The fixes part of it, just have the one error now.
PHP Deprecated: Implicit conversion from float 13.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 304
Sorry.. with the above 2 fixes, I can't replicate the error. What is the code for line 304 in wxsimcsv/index.php ?
I'm getting the following two errors.
PHP Deprecated: Implicit conversion from float 15.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 304
PHP Deprecated: Implicit conversion from float 15.5 to int loses precision in C:\inetpub\weathercat\wxsimcsv\index.php on line 319
Here is the code.
$forecastdate = $fday." ".$fdt." ".$fmonth." ".$fy." ".$lng[24]." ".date('g:00 A T' , mktime($data[3][3]+$dst, 0, 0, $data[3][1], $data[3][2], $data[3][0]));
$forecast = date('YmdH' , mktime($data[$i][3]+$dst, 0, 0, $data[$i][1], $data[$i][2], $data[$i][0]));
Then try changing them to
$forecastdate = $fday." ".$fdt." ".$fmonth." ".$fy." ".$lng[24]." ".date('g:00 A T' , mktime((integer)($data[3][3]+$dst), 0, 0, $data[3][1], $data[3][2], $data[3][0]));
$forecast = date('YmdH' , mktime((integer)($data[$i][3]+$dst), 0, 0, $data[$i][1], $data[$i][2], $data[$i][0]));
You did apply the change to usersettings.php of $dst = (integer)date("I"); //Set Daylight Savings Time
Thanks Ken. Everything is working now. :-)
