Web Weather => Weather Website PHP/AJAX scripting => Topic started by: Guillermo Villan on August 05, 2016, 02:56:24 PM
Any solution to this problem "unable to load data SAAR RC = 302 Moved Temporarily"???
www.wxelortondo.com.ar
guillermo
Yes, the US National Weather Service has decommissioned the weather.noaa.gov website (source of the METAR info).
Update the get-metar-conditions-inc.php to Version 1.14 to fix the problem.
You can download it from http://saratoga-weather.org/get-metar-conditions-inc.php?sce=view
I also recommend you download this update (http://saratoga-weather.org/wxtemplates/Test/check-fetch-times.php?sce=view), upload to your site, then run check-fetch-times.php?show=versions to check your Saratoga template for needed script updates. It will direct you to the updates tool page where you can get a custom .zip file with all the core script needed updates included.
Best regards,
Ken
