Just noticed that my barometer readings on my WH3000SE, are around 10 hpa to the lower side than what all the different weather services are reporting from the area. However, I live up relatively high (around 90 meters above sea level), so I'm not sure if that would be the reason for my lower readings ? If not how do i calibrate the station? I also have a GW1000
