Author Topic: Monitor More Than One Channel  (Read 3572 times)
Offline jimform2k1
« on: March 31, 2011, 01:11:13 PM »
Hello,
Are there any weather radios that can monitor more than one channel at a time?
If I live near Detroit MI, I can get WB channel 7 and channel 4 in Ontario.
Or this that what a scanner is for? (but I'm only interested in the weather band).
Offline W3DRM
    • Emmett Weather
Re: Monitor More Than One Channel
« Reply #1 on: March 31, 2011, 04:28:04 PM »
Weather Band radios receive stations that typically are "on the air" on a 24/7 basis. Listening to both channels simultaneously or having two radios would, IMHO, be next to impossible. A scanner, by its nature, would merely stop on a given active channel and sit there until the carrier dropped allowing it to move on to the next channel.
Thus, listening via a scanner wouldn't be possible unless it had a feature, which some do, to pause on an active channel for only a given period of time before moving on to another. The result would be a very chopped-up conversation and not very desirable.
--- RIPE Atlas Probe - 32849
Offline LFWX
  • Liberty Township, Butler County, Ohio
    • Liberty Fairfield Weather Center
« Reply #2 on: March 31, 2011, 07:15:15 PM »
My Uniden scanner can "watch for" a S.A.M.E. signal while scanning, without the "chopped-up conversation" problem, however it will only do this for one weather band frequency (assuming this hasn't changed on newer models - you may want to check the Uniden webpage).
More than one weather radio, or more than one scanner, may be the only solution.
www.LFWeatherCenter.com
CWOP: DW1039
CoCoRaHS: OH-BT-1
Weather For You: DW1039
Midwestern Weather Network
Offline groze
« Reply #3 on: April 22, 2011, 02:22:56 PM »
jimform2k1
If you are coverd by two frequinces and want to hear warnings for both. You need to have 2 S.A.M.E weather alert radios.
until the Ontario, Canada  weather service & Detroit weather service agree to rebroadcast warnings for each other.   They can be programed to broadcast warnings for Essex County, Ontario  & Wayne County, Michigan.   They may already do this.
« Last Edit: April 22, 2011, 02:24:51 PM by groze »
