GW1000 firmware 1.5.7 released:
I do not get a firmware update button for this version nor can I find it online. Is 1.5.7 only for beta testers?
You must be on your home network to do this.
If you open up WSView and in Menu select 'Device List'
Select your GW1000
You will now see your live data displayed with all the available sensor data displayed.
At the very bottom it will show the version of Firmware you are running on your GW1000
Normally when you select your GW1000 in the device list you will be presented with a screen to update the firmware if one is available for your device.
If there are non available it will go straight to displaying your live sensor data.
