Author Topic: WD trends in Saratoga template [Resolved]  (Read 962 times)
Offline Vasco
    • PWS
« on: March 29, 2023, 01:54:48 PM »
Another trivial question: where can I change the current pressure, shown to 3 d.p., to an integer value like all the rest?
I've tried using rtrim($baro0minuteago,'.000') and round($baro0minuteago,0) in WD-trends-inc.php, to no avail. Note that $baro0minuteago is an integer in testtags.php. . .
EDIT: just found d.p. settings in ajaxWDwx.js. . . but 3 d.p. is for imperial units.
« Last Edit: March 29, 2023, 06:51:56 PM by Vasco »
Ecowitt GW1102 (with GW2000) + Weather Display in Windows 10
Re: WD trends in Saratoga template
« Reply #1 on: March 29, 2023, 02:20:01 PM »
PHP w/o ajaxWDwx.js enabled is displaying the current line for baro as an integer (no decimal point/digits after).
When ajaxWDwx.js starts execution, the value flips to show the 3 digits of zero after a decimal point.
Odd.. you have set
dpBaro = 0;   // was 1 in the script so that should have turned off the decimals.
You might try changing
set_ajax_obs("ajaxbaro",pressure.toFixed(dpBaro) + uomBaro); to
set_ajax_obs("ajaxbaro",clientraw[6] + uomBaro); to avoid the math.
Offline Vasco
    • PWS
« Reply #2 on: March 29, 2023, 04:56:22 PM »
Odd.. you have set
Also tried setting next line
dpBaroNoU = 0   // was 1
- note typo has dbBaroNoU - but that didn't work. Nor did setting imperial
dpBaroNoU = 0   // was 3
But WD-trends-inc.php uses "ajaxbaroNoU", not "ajaxbaro"?
<td><span class="ajax" id="ajaxdewNoU"><?php echo $dew0minuteago?></span></td>
defined as
//Pressure...
var pressure = convertBaro(clientraw[6]);
set_ajax_obs("ajaxbaroNoU",pressure.toFixed(dpBaroNoU));
set_ajax_obs("gizmobaro",pressure.toFixed(dpBaro) + uomBaro);
If you put id="ajaxbaro" in WD-trends-inc.php instead you get an integer plus units. . . see attached.
« Last Edit: March 29, 2023, 06:09:04 PM by Vasco »
« Reply #3 on: March 29, 2023, 06:07:18 PM »
Yep.. sorry.  My bad.  You are correct; the one for ajaxbaroNoU should be done with clientraw[6].
Even though I wrote this stuff, sometimes my memory is bad and I should have checked the HTML of wxtrends.php before posting.
« Last Edit: March 29, 2023, 06:08:52 PM by saratogaWX »
Offline Vasco
    • PWS
« Reply #4 on: March 29, 2023, 06:23:40 PM »
Still no good. Tried
set_ajax_obs("ajaxbaroNoU",clientraw[6] + uomBaro);
and
set_ajax_obs("ajaxbaroNoU",clientraw[6]);
But still got 3 d.p.
« Reply #5 on: March 29, 2023, 06:36:01 PM »
I'm seeing the page load w/o the 3 decimal places (just the integer) for current baro.
Try doing a shift-reload to refresh the cache with the updated JavaScript.
Your current ajaxWDwx.js has
set_ajax_obs("ajaxbaroNoU",pressure.toFixed(dpBaroNoU)); and
var dpBaroNoU = 0; // was 3, default for Imperial trends data
dpBaroNoU = 0;   // was 1
and acccording to JavaScript a number.toFixed(0) should produce a rounded integer display.
Offline Vasco
    • PWS
« Reply #6 on: March 29, 2023, 06:46:04 PM »
. . . of course it does, if you remember to do Ctrl-F5  :oops: :oops: :oops:
Sorry (again), Ken.
P.S. did you check the typo I mentioned? (Edit: around line 171 of ajaxWDwx.js)
Presumably that's why changing metric dbBaroNoU to 0 didn't work: it had to use imperial dpBaroNoU = 3 instead.
« Last Edit: March 30, 2023, 07:28:49 AM by Vasco »
« Reply #7 on: March 29, 2023, 06:53:52 PM »
Ahh.. that dbBaroNoU = 1; typo has been there since the script was released 13-Dec-2006 and you are the first one to spot it.  I think the same typo may be in other of the ajaxXXwx.js scripts too, since they were largely based on this (primeval) script.
You have good eyes!
Offline Vasco
    • PWS
« Reply #8 on: March 29, 2023, 06:58:17 PM »
You have good eyes!
Once upon a long time ago I was an editor, doing a lot of proof-reading. . .  :-)
Re: WD trends in Saratoga template [Resolved]
« Reply #9 on: March 29, 2023, 07:56:16 PM »
Just checked.. only ajaxWDwx.js and ajaxWEEWXwx.js have the typo (whew!  \:D/ ).  The other scripts do not have the issue.
