Can we presume that all of you folks who are having problems with 5.9.x, are reporting those problems to Davis?
Reporting the problems here is great - but it won't get the problems fixed.
I'm still trying to decide whether to report it to Davis or Tinplate @ SoftWx.
(Thus the poll I just posted.) If this is truly a Virtual VP issue, reporting it to Davis would probably be little more then a waste of time.
Well, I got "yelled at" when I suggested it might not be a Davis issue - so I suggested reporting it to Davis. But I'll stick my neck out and try to outline my reasoning.
First - any software program that's written to communicate with a port (serial, USB, whatever) has (by standards) the right to assume that it has exclusive access to that port.
Also, if new hardware is introduced (Vue, WeatherLinkIP, etc.), with new capabilities, there may be additional speed or timing issues that cause changes in the software - but the same rules apply.
So: If:
1. WeatherLink software works properly when it has exclusive access to the port.
2. VirtualVP makes it look to WeatherLink like it has exclusive access to the port.
3. New version of WeatherLink doesn't work properly when VirtualVP is used.
