Author Topic: WL.com Bulletin  (Read 1524 times)
Offline meteosat
WL.com Bulletin
« on: January 30, 2023, 05:54:49 AM »
I've noticed that the temperature values above the temperature bars on the bulletin page are no longer visible.  You can see the current value along with the high and low values if you hold the mouse cursor over the bar but it was nice to see at a glance all the current values.  Anyone else noticed this change.
Offline Dador
    • Jejkowice
Re: WL.com Bulletin
« Reply #1 on: January 30, 2023, 12:03:04 PM »
Basic plan, works fine.
Davis VP2 Plus + Barani MeteoShield + DIY Rain Collector Heater + Davis 6345CSOV + Davis 6332 Anemometer.
Ecowitt GW1000 + 7xWH31 + WH32 + WN30 + WH57 + WS68 + WH40.
Offline PaulMy
Re: WL.com Bulletin
« Reply #2 on: January 30, 2023, 02:35:55 PM »
I have both a Basic and Pro WL.com account.
In checking and switching between the two Bulletin views sometimes the temperatures show above the graph and other times it does not.  It is a hit and miss, and seems that when first login it shows, then after a browser reload or switch between stations it doesn't.
https://www.weatherlink.com/bulletin/a3a3c5e7-b8bd-4910-ba3a-f6ad6e1f09d1
https://www.weatherlink.com/bulletin/9e396562-3f54-435e-a363-34e63b9d35ec
Enjoy,
Offline Mattk
Re: WL.com Bulletin
« Reply #3 on: January 30, 2023, 03:39:39 PM »
Really can't recall ever seeing values above the bars?
Offline PaulMy
Re: WL.com Bulletin
« Reply #4 on: January 30, 2023, 04:21:00 PM »
Really.
Attached is my Basic plan Bulletin after I did a new login, and it shows the measurements.
Also my Pro Bulletin just a minute or so later showing the measurements.
Then a browser refresh and then no measurements.
Enjoy,
Offline Mattk
Re: WL.com Bulletin
« Reply #5 on: January 30, 2023, 05:16:18 PM »
No, not a thing in that regard, specifically just checked this, 3 accounts, 10 stations, hover overs work ok (except for Total Rain) but no super script vales
Offline meteosat
Re: WL.com Bulletin
« Reply #6 on: January 31, 2023, 06:58:12 AM »
Thanks for the replies.  Just refreshed page using F5 and on the 3rd attempt the values suddenly appeared again.  Reloaded page and they have gone again. F5 twice and they come back. Might be a complete coincidence but it only seems to have started doing this since I went over to Windows 11.
Offline meteosat
Re: WL.com Bulletin
« Reply #7 on: February 02, 2023, 06:50:52 AM »
Had a very quick reply from Davis Support yesterday which acknowledged that they know about.
"This is a bug that has been reported and being worked on. The reason it is so hard to fix is it does not happen to all customers. For instance your station on my PC looks fine. It is also intermittant. It comes and goes. However we are looking at it and hope it will be fixed soon."
Offline bellenden ker
Re: WL.com Bulletin
« Reply #8 on: February 05, 2023, 02:14:02 AM »
Thanks for the info we will just wait and see if fixed i also just changed to windows 11 after a change of computers
Thanks for the reply
cheers Mike
