Weather Station Hardware > Weather Station Pictures
Mounting on Cinderblock fence
(1/2) > >>
jagman653:
I recently decommissioned my old Oregon Scientific an got an Ambient WS2000. The mounting hardware offered by Ambient seemed to be oriented to those who want the station on a tall pole. I wanted low enough to easily work on for adjustments, battery replacement, etc. After nosing around a bit I came across this Universal Antenna Pole Outdoor Mount on Amazon:
https://www.amazon.com/Antenna-Pole-Outdoor-Mount-Universal/dp/B088H8BMN3/ref=pd_lpo_2?pd_rd_w=iXtMc&content-id=amzn1.sym.196193c7-f80f-4550-90d9-c8be3a442748&pf_rd_p=196193c7-f80f-4550-90d9-c8be3a442748&pf_rd_r=H2NDRXRFFWE5HFMF7RNZ&pd_rd_wg=VFvN0&pd_rd_r=48d6d4d1-2892-4e57-bd7f-ffca05d08a56&pd_rd_i=B088H8BMN3&psc=1
It's cheap and works perfectly. As you can see, I first attached a 2x6 on the wall and then attached the mounting bracket to it. The reason for this is cinderblock is a composite of cement & gravel and the masonry drill bit tends to drift when it encounters a piece of gravel. You can see the problem in the photo where I had to abandon my first try for the lower left screw.
A kitchen ladder allowed me to see the little leveling bubble that ensures accurate readings of rain, wind direction, etc.
Perhaps you can see the edge of a piece of 0.02" brass shim stock slid under the lower edge of mounting bracket. That's there because the mounting bracket seems to be designed to provide a slight tilt off of vertical as might be necessary to clear the roof edge when mounting an antenna on the eves of a house.
Vasco:
Hate to have to tell you, but walls/fences are BAD NEWS for temp measurements. . .
Notsorusty:
Keep in mind that the mounting of all weather stations is usually a compromise of some kind especially with an All-In-One device. Either a height restriction, existing trees, buildings, water, roofs, pesky HOAs, etc. Even safety when maintenance is needed. Possibly a slightly taller pole could be substituted since the mounting bracket seems easily accessed for maintenance.
jagman653:
--- Quote from: Notsorusty on December 31, 2022, 03:05:28 PM ---Keep in mind that the mounting of all weather stations is usually a compromise of some kind especially with an All-In-One device. Either a height restriction, existing trees, buildings, water, roofs, pesky HOAs, etc. Even safety when maintenance is needed. Possibly a slightly taller pole could be substituted since the mounting bracket seems easily accessed for maintenance.
--- End quote ---
Thanks, Vasco & Notsorusty.
As an engineer with training and experience in heat transfer I'm well aware possible effects on the readings. However,  I believe the sensors are high enough above the fence to minimize the effects. I'll be keeping an eye on readings and comparing with other nearby Weather Underground stations.
Yes, a longer pole is possible. I might do that if necessary. No HOA restrictions at any might I might be willing to install.
Ed
ocala:
--- Quote from: jagman653 on December 31, 2022, 03:13:08 PM ---
--- End quote ---
Ed
--- End quote ---
You can't compare with nearby stations. Your micro climate is just that. Yours. Where those other stations are located and how they are sighted is their micro climate. That's why when you look at a map of stations close together you will see they are have different readings. To do it right get a pole and mount the unit well above that block wall.
[#] Next page
