Author Topic: Two WS90s (Experiment only)  (Read 1489 times)
Offline Rover1822
Re: Two WS90s (Experiment only)
« Reply #25 on: January 01, 2023, 10:07:30 AM »
Yes, I could try to make either of the WS90s be closer to The Wh40 and the manual, the point is , even the WS90s don't agree. So using someone else's calibrations, as are posted all over the place, might be pointless. I'm not interested in making the WS90s work at this point, just rely on my WH40s. (This was just an experiment :)  )
Also this was just one event, will see what happens next time
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Ra1nman
« Reply #26 on: January 01, 2023, 10:45:12 AM »
Fair enough :grin:
Ecowitt WS90 ׀ GW2000 ׀ WH51 ׀ WH32EP ׀ WH40
Offline Rover1822
« Reply #27 on: January 09, 2023, 12:30:11 PM »
OK, Another rain event. The new WS90 and the WH40 are closer. The older WS90 (Kickstarter), is still off in LA-LA land.
There are no calibrations in effect for any of the sensors
So the total daily totals are
0.43"    Manual stratus
0.46"    WH40 with extension
0.60"    Old WS90 (LA-LA)
0.46"    New WS90
Graph
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BoDuke
  • Ambient Weather, Ecowitt, WeeWX, Custom PHP
« Reply #28 on: January 09, 2023, 01:02:27 PM »
Until 2:24, it does look promising that the WH40 and new WH90 are fairly close.  However, and maybe I'm not understanding the graph, but was there rain after 2:24 on January 9?  If so, it looks like the WH40 and original WS90 did not measure it while the new WH90 did.  I find that more puzzling.
Offline Rover1822
« Reply #29 on: January 09, 2023, 01:10:33 PM »
I believe there was Heavy fog / Dew at that time, I am attributing the New WS90 continued increase in rain totals to that, am I correct in that assumption?  No idea. What strikes me is that this time it was closer to the WH40, if you look at my previous graph in this thread, that wasn't the case. I have made no changes.
I'm trying to collect data , to maybe , calibrate the WS90s, right now, I can't . I have all of this in spreadsheets, looking at rain rates etc. I also use my own custom server to receive the data, so the formatting , and time points are on point.
But , I have only done this twice now, as I recently received the newer WS90
so basically  ](*,)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rocketman
« Reply #30 on: January 24, 2023, 06:43:29 PM »
Any updates on this ?
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Offline BaseLine
« Reply #31 on: January 25, 2023, 05:28:47 AM »
I still don't get the point of testing/comparing your equipment in uncontrolled environment. For fun? Sure, have fun :) but that's about it.
Indoors, same temperature, a reliable fake rain system that can dump exactly the same amount of water in exact time over exact same area.... now you got a system to compare and tune your equipment.
Fun fact - when you take your freshly calibrated and now squeaky clean toys outdoors, place them at different locations and heights, you will get slightly different results and none of the are "wrong".
Cheers!
Have fun!
Sun cooked nothingburger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline Rover1822
« Reply #32 on: January 25, 2023, 11:20:31 AM »
I've had a few other rains , same trend. My kickstarter one reads way high, when compared to my new WS90, both being located within 2 feet of each other and same height. The new one is much closer in rain readings to the manual stratus and the WH40s. I will be getting more rain today.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rover1822
« Reply #33 on: January 26, 2023, 09:07:33 AM »
Yesterday's rain readings from a heavy event . This will be the last time I post the data. Really no point as the variances are so large and inconsistent when compared to the previous ones . Bottom line, I trust the WH40 and the manual rain gauge, the WS90s can't even agree with themselves, which may just a difference in date of manufacture , no idea.
1.02"    Manual stratus
0.98"    WH40 with extension
2.44"    Old WS90 (LA-LA)
1.50"    New WS90
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BadWolf72
« Reply #34 on: January 26, 2023, 09:11:36 AM »
Rover1822 its interesting to see the two units compared with each other and maybe there is a difference in components inside the units with one been a kick starter and the other been a lets say a better finished product for the general market, it would be nice if we knew what if any changes in hardware was made between the kick starter and the newer model.
Myself i only have 1 ws90 and 1 ws65 for the most the are fairly close in there readings for wind, temp, etc etc.....but i have not had any rain yet to compare the two and in all honesty i do not know how accurate the ws65 is in itself.
Thank you for sharing this with us
Martiin.
My Weather Station Information All 868Mhz
Ecowitt wittboy                             WS90
Ecowitt weather station                 HP2551
Ecowitt Gateway                           GW1100
Ecowitt Soil Temperature               WN34S
Ecowitt Air Quality Sensor (PM2.5) WH41
Ecowitt Soil Moisture Sensor          WH51
Ecowitt Lightening Sensor              WH57
Offline Rover1822
« Reply #35 on: January 26, 2023, 11:41:33 AM »
From experience, and many, many other posts in here the WH65 (osprey) tends to over read. But that can easily be calibrated if you have a quality manual rain gauge like a stratus located as near as possible to the WH65.
Mine needs cleaning right now, so not including results from it :)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BadWolf72
« Reply #36 on: January 26, 2023, 12:04:42 PM »
Thank you Rover1822, i have a ClimeMET CM1016 manual rain gauge if that is any good..... but how close do i need it to the array and same height?
Thank You
Martin
Offline Rover1822
« Reply #37 on: January 26, 2023, 12:07:08 PM »
In my opinion, as close as possible, a few feet, and elevate as close as you can without interfering with each other.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rocketman
« Reply #38 on: January 26, 2023, 03:03:55 PM »
Rover1822, it is possible measure a set amount of water and pour on each sensor in a controlled way ?
« Last Edit: January 26, 2023, 03:54:27 PM by Rocketman »
Offline Rover1822
« Reply #39 on: January 26, 2023, 03:30:45 PM »
No.
Not without a lot of engineering , and complete knowledge of how the sensors read. Neither of which I am going to pursue. These are not like tipping bucket sensors.
But, I encourage others to try, and maybe , maybe, we get some word back from the manufacturer.
Also, Please, please, understand, these are just my experience, they should not be interpreted to be a global statement on the device. Nor should I be considered some testing guru, these are solely my experience. I would be interested in others experiences
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rocketman
« Reply #40 on: January 26, 2023, 03:56:49 PM »
Sorry , I wasn't thinking .  [tup]
