wanted to see/ask about some issues im having with this PWS.
5 and 1 sensor has fresh batteries, and the display is showing 5 bars of signal strength from the sensor and the wifi. this particular model indicates that no hub is required for this PWS.
after a very painful and long drawn out process of connecting the PWS to my wifi and wx underground, it finally connects. however, within about 3 hours..for no known reason, it keeps disconnecting. only way to fix it is to reset the display and start over.
the sensor is only able to communicate on 2.5 ghz networks and not 5ghz. i disabled my 5ghz network on my router admin page.
i have changed my wifi channel (to 11), changed all 3 channels on the sensor itself, and it still disconnects after 3 hours or so.
on a facebook group that i subscribe to, someone else (with a accurite atlas) described the same issue. she purchased the access hub and the problem went away. not sure why accurite wouldn't include this/or even advertise the pws that no hub is required if you need it to stay online and connected. i have until october 12th to return this if I need to. if it keeps discoonnecting, i will return this for another brand. i really like the accurite interface and app it has very useful graphs. I really want this to work. only thing i haven't tried is moving the sensor closer to the display. any help would be appericated.
