Author Topic: WeatherLink Live - station maintenance  (Read 702 times)
Offline marylandwx
« on: January 29, 2022, 04:13:57 PM »
I just received and setup WeatherLink Live but wasn’t sure what I should do to prevent erroneous readings when performing station maintenance on my VP2. I’ve always put the console in setup mode, is there an equivalent on the WLL module? I did find a “test mode” within the app but I’m not sure if that’s what I’m looking for.
Thanks in advance!
Re: WeatherLink Live - station maintenance
« Reply #1 on: January 29, 2022, 06:35:26 PM »
Just unplug the sensors.
Offline marylandwx
« Reply #2 on: February 02, 2022, 04:19:28 PM »
Thanks for this suggestion but I’m worried about jostling the station and getting the dreaded tip of the rain bucket that you can’t delete in WLL. My station siting requires a ladder so it isn’t the easiest to get up there and gently open the ISS panel to unplug the sensors without shaking it a bit.
I wrote to Davis to see what they suggest but I’m not sure when I will hear back from them.
Offline Bashy
  • brecklandweather.com/pws2021
    • Breckland Weather
« Reply #3 on: February 02, 2022, 10:42:11 PM »
Would pulling the power and batteries from WLL do the same thing? I don't think the ISS stores any data, heck, i might be wrong so get confirmation, also, i don't know if you lose settings after x amount of time either so clarify that too...
Kind regards
Bashy
« Reply #4 on: February 02, 2022, 11:28:20 PM »
It does not.
Offline Bashy
    • Breckland Weather
« Reply #5 on: February 03, 2022, 02:07:33 AM »
It does not.
Thanks, i thought not but i do tend to jump the gun :/
Kind regards
Bashy
Offline Mapantz
    • Wareham Weather
« Reply #6 on: February 03, 2022, 07:16:48 AM »
I have never used the setup mode when doing maintenance. I always unplug the rain gauge, regardless of what I am cleaning. It doesn't cause any issues, unless of course, it's raining while you're doing the maintenance..  \:D/
Offline marylandwx
« Reply #7 on: February 03, 2022, 04:31:38 PM »
Thanks all for the suggestions and the idea to unplug the rain sensor. To take WLL offline, it looks like Bashy had the right idea!
Here is the official response from Davis:
Actually, regarding the Weatherlink LIVE, you would need to reset the weatherlink LIVE device by removing 1 battery and disconnecting from AC power.
When you are done with your weatherstation maintenance,
1. power up the Weatherlink LIVE
2. Make sure you are no more the five feet from the weatherlink LIVE device with your smart phone, blue tooth enabled, and logged into your weatherlink app
3. Tap the torso/snowman icon in the top right of the weatherlink app
4. Under Devices tap the right arrow next to <Station Name>
5. Next tap "Edit" next to <Station Name>
6. Tap "Network Settings" and follow the instructions on the app to connect to your network.
Offline Bashy
    • Breckland Weather
« Reply #8 on: February 04, 2022, 03:02:46 AM »
I think for your situation the official way is ideal, whilst the majority would just pull the bucket plug.
Me, i would have been stupid enough to have pulled all the damn plugs, not realising that that was just plain idiocy lol
Kind regards
Bashy
