Author Topic: Agro software  (Read 4404 times)
Offline dinomo
Agro software
« on: May 18, 2009, 04:22:57 PM »
Hello, if someone uses an additional module for the control agrocultural? Price is somewhat less than the WL, so I wanted to know what is possible before I buy.
Offline Weather Display
Re: Agro software
« Reply #1 on: May 18, 2009, 05:21:51 PM »
are you refering to a module (agriculture) for weather link, or?
Brian
info@weather-display.com
Offline dinomo
Re: Agro software
« Reply #2 on: May 19, 2009, 03:32:31 AM »
Jea. That's it.
It is a module for agriculture for weatherlink.
Re: Agro software
« Reply #3 on: May 19, 2009, 06:26:23 AM »
this thread needs to be moved to the weatherlink section then  by a admin , thanks
Brian
Offline dinomo
Re: Agro software
« Reply #4 on: May 19, 2009, 12:26:28 PM »
O my god, I sincerely apologize. Please administrator to move the topic.
Re: Agro software
« Reply #5 on: May 20, 2009, 02:13:10 PM »
Not a problem.. moved to WeatherLink section :)
Offline d_l
  • Slide Mtn - Mt Rose
Re: Agro software
« Reply #6 on: May 20, 2009, 03:57:18 PM »
I'm pretty sure that you have to have a WL version first to be able to use the Agricultural/Turf Management Module as it integrates into WL.  See: http://www.davisnet.com/product_documents/weather/spec_sheets/6511_Spec_Rev_A.pdf for what it does.
I have the following additional questions for anyone that might have it:
Will this module also work with the WLIP?  Davis doesn't say that it does.
Are the reports that it generates formatted similar to the NOAA, or Sunrise & Sunset-type reports of WL or is the info simply attached as another column in the Browse Records or both?
--Dave--
Offline Arthurhh
  • IT Fixer
    • Tokoroa Weather Live
Re: Agro software
« Reply #7 on: May 20, 2009, 04:57:51 PM »
No very expalantive notes for this product, it has become clear that it requires a soil temp and leafd wetness sensor but no details (apart from it obviously needs all the std sensors and perhaps a solar) on what else or for that mater what it actually produces.
I am interested in its functionallity but I guess I am going to have to write to davis and ask questions.
Offline d_l
Re: Agro software
« Reply #8 on: May 20, 2009, 05:23:51 PM »
It absolutely needs a solar sensor for the ET calculation and of course it would need the other two sensors for the soil temp and leaf wetness reports.  I guess if you didn't have those sensors, the report capabilities would be restricted.
I'm mostly interested in its ET capabilities.  The standard WL ET output is pretty limited if say you wish to know the total ET over certain periods of time that are not simply a monthly or daily interval.  Sure you can add up the daily bar values when you set the plots to a weekly range, but that is a pain to do. It is supposed to sum total ETs over your chosen time interval.
--Dave--
Offline Arthurhh
  • IT Fixer
Re: Agro software
« Reply #9 on: May 20, 2009, 06:04:35 PM »
It looks like your purpose could be accomplished with a little bit of PHP and maybe mysql work.
Mine probably could as well but my skills are not that good
