I believe that value comes directly from Davis station.
This isn't a value that can be
"read" from the
Davis station, it is calculated by the station (for display on the console) and it is also calculated by the
WeatherLink software. It is supposed to be something that was added to
VWS, but it only works correctly for the THW Index, the THSW Index still doesn't work correctly (always shows the current real temperature).
WeatherLink doesn't even show the current THSW and the last I heard from Ed (creator of VWS) the
VWS THSW Index was not working because of a problem with the DLL from Davis.
You can, however, see the THSW plotted on a graph and it often goes below the THW when the sun isn't shining (same happens on the Davis display), so I don't think they have all the bugs worked out of this calculation.
