Hello,
I decided to bring this issue up again since it remains unsolved
http://www.wxforum.net/index.php?topic=1896.0every once a while for some unknown reason weatherlink stops uploading new achive data
there are no CRC errors of anykind, and no new data appears in the data base until you taken the station into setup mode and back out online and then the new data downloads return,
](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
but data since downloads stop has been lost
has anyone else experienced this frustrating problem
Davis has not given me a answer other than to upgrade the weatherlink software, it still remains unclear whelter it is a software or hardware issue.
It should be noted that this is a serial datalogger using weatherlink 5.71, on a windows xp system. I am also using Virtual Vp and Weatherdisplay is also running without any issues all the weather uploads seem ok
any help on to what is causing this issue would be helpful, Thanks
Jeanette
