Author Topic: Weather Data Posted to Internet via Wildblue Satellite Internet  (Read 2730 times)
Offline BayouOsFan
  • Robert Lanier
I am new to the personal weather stations.  After a few weeks of research, I have decided to purchase a Davis Vantage Vue and want to send the data to the internet.  But I am wondering what would be the best software setup for satellite internet (Wildblue); one of the downsides of country living.  I currently have a modem (provided by Wildblue) and a Cisco router.  My computer does not run 24/7, but if that would make for a better solution, that would not be a problem.
Any thoughts or other suggestions concerning uploading data via satellite would be appreciated.
Robert L.
Clinton, LA
I'm doing better than most and not as well as a few others, but I'm doing better than I deserve.
Offline dalecoy
    • Lee's Summit, MO
Re: Weather Data Posted to Internet via Wildblue Satellite Internet
« Reply #1 on: March 07, 2011, 07:46:09 PM »
Are you thinking of:
A.  Having your own website to display your weather information?  and/or
B.  Having some other commercial website(s) receive your data and perhaps display it?
« Reply #2 on: March 07, 2011, 07:48:24 PM »
I would assume that your router and WildBlue modem would act like any other always-on broadband internet connection.
I am not really familiar with the Davis equipment, but I see that they have a module that plugs into your console that gives you an ethernet connection. This "Weather Link IP" could connect to a port on your router. That way you could avoid running the PC all the time.
http://www.vantagevue.com/products/product.asp?pnum=06555
I don't see any reason that there would be any difference between the satellite connection and any other system such as DSL or cable modem. It is just a TCP/IP connection from the PC or IP module.
Take a look over at this thread regarding Weather Link IP: http://www.wxforum.net/index.php?topic=10862.0
« Last Edit: March 07, 2011, 07:59:04 PM by miraculon »
    • Watts Bar Weather
« Reply #3 on: March 07, 2011, 07:56:57 PM »
Check to see if you have fair access or other bandwith limitations.  Some providers have a limit on download or upload usage which might cost you more, or slow down your speed.
Offline dalecoy
    • Lee's Summit, MO
« Reply #4 on: March 07, 2011, 08:06:21 PM »
The big difference is the latency.  Because the signal is traveling over 22,000 miles to the satellite and the same distance back, it takes the transmitted packet about 1/2 second to get to its destination.
I have no idea how (or if) that would affect the WeatherLinkIP.  If considering that option, I would recommend a call to Davis support, to ask them.
Offline BayouOsFan
  • Robert Lanier
« Reply #5 on: March 07, 2011, 08:09:05 PM »
I think initially it will just be using the standard website to post the info.  But I believe down the road I may want to try to make my own website.
« Reply #6 on: March 07, 2011, 08:10:57 PM »
Do you really want/need always-on reporting?  You coul just upload at periodic intervals
Offline BayouOsFan
  • Robert Lanier
« Reply #7 on: March 07, 2011, 08:34:17 PM »
Do you really want/need always-on reporting?  You could just upload at periodic intervals
I don't really "need" it, but it would be nice.  With the WeatherlinkIP, you can choose the time intervals to upload your data?  That's why I figured I would get on here and ask the questions before I make the purchase.  There seems to be quite a few people on this site that are VERY knowledgeable about this stuff!
« Reply #8 on: March 07, 2011, 08:36:23 PM »
Remember that if you go WLIP you will have to figure out how to get the data back when you go to your own site.
Offline dalecoy
    • Lee's Summit, MO
« Reply #9 on: March 07, 2011, 08:39:26 PM »
If you use the WeatherLinkIP with WeatherLink software, the data (archive) can be also kept locally.  And/or it can be rather easily retrieved from the WeatherLink.com site.
« Reply #10 on: March 07, 2011, 09:22:56 PM »
But then it will not be live, right?
