Weather Related Organizations => WeatherUnderground => Topic started by: Randall Kayfes on January 22, 2023, 01:44:58 PM
My WeatherLink PC reports to WeatherLink.com
WeathLink.com forwards my data to WeatherUnderground.com
WeatherLink PC and WeatherLink.com are both up to date.
Is it just me or have others been offline from WU for a couple of days?
It's the same problem here. I never know where the problem is. It's either WU or Davis but it does usually come back. Since it's the weekend it probably won't get fixed until tomorrow.
Lots of people (https://www.wxforum.net/index.php?topic=44946.msg456130#msg456130), myself included.
I had the same problem. I have an Acurite 5in1 and had to go to the setup screen via the IP address and re-submit the setup info. Hope this helps.
This is posted on WU support page.
WU has been offline for me also, it will come online for a couple of hours then die again. The issue they are having never gets explained to the world after all they are IBM and do not have to tell the rest of us what happened.
It's a WU problem for sure. I'm back online right now but only updating every 20-30 minutes. Had to reboot the router to get it online. It's a new AcuRite 06086M WiFi display. I'm new to being online but not to AcuRite, been using, maintaining and doing minor repairs to them for over 12 years.
https://www.wunderground.com/dashboard/pws/KNCSALIS144 (https://www.wunderground.com/dashboard/pws/KNCSALIS144)
Offline again, this is getting old.
I have a Davis Vantage Pro 2 and also have problems with weather data not uploading to Weather Underground. This problem started yesterday and still not resolved.
My connection went down at exactly 8am EST yesterday morning. I have managed to get it back online 3 or 4 times but it doesn't last. It's online right now but I expect it to be down within 30 minutes. I've read in several different places that it seems to have hit nearly every brand so it's a WU issue.
Attempts to send what should be a valid update request via a browser are returning gateway errors (504, 503, 502)
request sent:
https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?&ID=yyyyyy&PASSWORD=xxxxxxx&dateutc=now&baromin=29.9146&tempf=62.6&action=updateraw
I am getting a 504 error when sending an update to WU
I had to tell my weather program to not do the updates because it was hanging up the program.
I will keep an eye out here to see when the issue goes away.
Message "The remote server returned an error: (504) Gateway Timeout."
request sent:
I have a CRON job that executes a script every 5 minutes that accesses data directly from my WeatherLink Live and issues an upload request to WU. My uploads starting failing about 7AM CST on Saturday morning. As others have noted, there is intermittent success with uploads, however it's often 3 or 4 HOURS between successful uploads. It's now been over 48 hours since I first saw the issue so this must be a major problem on WU's end.
Steve
See https://www.wxforum.net/index.php?topic=44946.msg456289#msg456289
Mine is working again, too.
Thanks for the heads up Vasco!
I can confirm that I was able to upload to WU just now
Hopefully everything is back to normal
Mine too
I'm UP also. Somebody has the weekends off. It's probably one staffer at IBM keeping the entire WU website going. I hope they don't ever retire.
If you got Weather-Display, use it to report to WU. I haven't noticed any problems in doing that.
Weather Display has not been able to connect regularly to WU for a day or two - connections timed out.
What does your WU Dashboard look like for the last few days?
Looks like IBM must have plugged their WU server back in at 8:50AM CST this morning. They've been receiving my uploads without fail since then.
Steve
I'm back online and updating, however graft and table are not updating in timely way.
