Author Topic: Mounting pole max OD?  (Read 2057 times)
Offline DennisD33
« on: May 20, 2020, 09:07:01 AM »
Question about Ambient Weather 2902B: what is the max OD pole the mounting U-bolts will accept?  A 2-inch Schedule 40 PVC pipe is 2.375 inches OD (2 3/8 inches).  Is this too big?    I bought this unit for my grandson but I want him to be the first to open the box, and I want to give him a complete package, including a pole.  Thanks in advance!
Re: Mounting pole max OD?
« Reply #1 on: May 22, 2020, 10:19:52 AM »
Recommended pole diameter is 1 to 2 inches according to the manual.
Offline DennisD33
« Reply #3 on: May 22, 2020, 10:34:27 AM »
Thanks, Galfert!  I like the galvanized pipe suggestion.  That will have an OD that will fit.  My grandson will be over the moon when he gets this unit!
I sure appreciate it!
« Reply #4 on: May 22, 2020, 10:44:01 AM »
The neat part of using the fence top rail pipe is that it is tapered at one end, allowing you to connect more than one section together. For the WS-2902B I recommend a height of about 15 feet. Connect top rails and bury 5 ft or cut it if you have the means. I know Home Depot will cut wood, I don't know if they would do the same for pipe. Then just put some concrete down and you are set. Be sure to use a post level.
https://www.homedepot.com/p/Empire-5-1-4-in-Polycast-Post-Level-720/100124903
You could also just use one section of rail and combine with wood fence post and then some people devise a hinge mechanism to service.
The 15 ft height is ideal for an all-in-one station. Best siting compromise for all sensors. This also allows you to reach for maintenance with an A frame ladder.
« Last Edit: May 22, 2020, 10:46:27 AM by galfert »
Offline DennisD33
« Reply #5 on: May 22, 2020, 10:57:14 AM »
Yes, that’s another good suggestion I hadn’t thought about.  We’ll mount the unit at 15 feet; that will also get it at the proper height/distance ratio from nearby small trees.  And we’ll insure that it’s dead plumb, too.
Thanks, again, Galpert!  I know my grandson will enjoy this forum, too!
Online Rover1822
« Reply #6 on: May 22, 2020, 11:01:16 AM »
Another thing you can use, is just EMT conduit
https://www.homedepot.com/p/1-1-2-in-x-10-ft-Electric-Metallic-Tube-EMT-Conduit-101584/100400412
Granted its only 10' but if mounting to the side of a building , works well
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline DennisD33
« Reply #7 on: May 22, 2020, 11:09:01 AM »
Thanks, Rover!  That’s another good suggestion.  I’ll check them both out at Home Depot.
Offline Mulberry Weather Guy
  • Just another old fart.....
    • Mulberry Weather Page
Offline DennisD33
« Reply #9 on: May 22, 2020, 11:19:38 AM »
Yet another great option, Mulberry!  I like the fact that it can swing down for maintenance.  (And at Staples, of all places!)  I might bury a long 4 x 4 post as you have done, and then mount this.
I’ll mull over all these great ideas.  I do appreciate your time and expertise, everyone!
Online Rover1822
« Reply #10 on: May 22, 2020, 11:22:19 AM »
If you go with EMT , this EMT coupling
https://www.homedepot.com/p/RACO-EMT-1-1-2-in-Set-Screw-Coupling-20-Pack-2026/203637545
I know you only need one but couldn't find a link. Will fit perfect in the U-bolts , what is nice is that you can square off the attachment to the station u-bolts , then just slide onto your pole and tighten the set screws. The one I have has 4 set screws 2 of which you wont use as the U-bolts will be there
Makes maintenance easier as the U-bolts can shift etc
Basically you are modifying the mount to be static to the pole
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline DennisD33
« Reply #11 on: May 22, 2020, 11:32:17 AM »
Yes, I like the idea of being able to micro-adjust with the mounting U-bolts using this connector.  I’ll certainly keep this in mind if we go the EMT route.  Thanks, Rover!
« Reply #12 on: May 22, 2020, 12:03:12 PM »
The post was a light steel tube 3" that was scrap at work. Staples was the cheapest by far on the post. Ans yes it's handy to swing down if needed. Post is anchored on concrete with 3/8 anchors, and won't move a bit. The satellite mount was my only cost, as the rest was scrap/extras from work.
Offline DennisD33
« Reply #13 on: June 24, 2020, 09:06:04 AM »
Here are two pics of the finished setup for my grandson’s Ambient PWS. (I hope I've attached these correctly. WU KSCSIMPS114, & Ambient Weather Dapple Gray, if I have those right.)  Like Galfert suggested, I used two 10-foot chain-link top-rail fencing tubes.  It worked out great!  I cut one to use as the 5-foot in-ground anchor pole, and used the remaining half-pole and full-length pole as the main 15-foot mounting pole.  I had to use two bolts angled at 90 degrees at the slip joint to secure it from wobbling because the slip joint is not snug enough.
I also devised a way to pivot the whole shebang to the ground using other chain-link fence hardware.  The bottom pivot cup has a screw in the side and into the pole to prevent the pole from accidentally popping out while lowering it.  The top cap is there basically just for looks, although I suppose it does provide some anchor and support.  The main anchor mechanism comes from the two clamps that hold the main pole to the 5-foot in-ground pole.  That pole is in about a 30-inch hole, then filled with concrete.  I also filled the in-ground pole with concrete for extra oomph.
Lowering the unit takes two people: one to hold the pole, the other to remove the two clamps, then loosen & slide up the upper cap.  The pole then lowers easily on the bottom pivot.  We did this several times in adjusting the unit to get the exact compass orientation, and it was quite easy.
I want to thank all the folks who offered suggestions for this project!  They were all very useful, and I got ideas and inspiration from each of them.  Thanks again, folks!
Dennis D33
Simpsonville, SC
Offline DennisD33
« Reply #14 on: June 24, 2020, 09:13:26 AM »
Sorry, folks, I don't think the first picture attached properly.  I'm new at this; I’ll try again. [ You are not allowed to view attachments ]
« Reply #15 on: June 24, 2020, 09:42:00 AM »
Nice!  [tup]
What was your total bill of materials cost?
Offline DennisD33
« Reply #16 on: June 24, 2020, 10:00:41 AM »
Oh man, good question.  I think overall less than $75.  That includes the two poles, all hardware doo-dads, and fast-set concrete bag mix.
« Reply #17 on: June 24, 2020, 10:21:27 AM »
Yeah I was just looking for an estimate. That pretty good. I'm sure this will help many people. Thank you for sharing.
