Author Topic: WiFiLogger - Connect your Davis console directly to the Internet via WiFi  (Read 113883 times)
Offline 92merc
  • BismarckWeather.net
« Reply #725 on: January 08, 2019, 05:01:27 PM »
You should be able to update the firmware.  Basically treat the Wifi logger like a Davis Weatherlink IP module.  Same directions and it should update.
Offline R_o_B
« Reply #726 on: January 08, 2019, 10:26:17 PM »
I have 2 questions:
- Is it possible to upgrade the firmware? How?
- Is it possible to send data to a proprietary system via post HTTP or MQTT?
Yes, indeed. Both the upgrade/update instructions (PDF document) and the MQTT information can be found in the first message of this thread 'WiFiLogger - Connect your Davis console directly to the Internet via WiFi'
R_o_B
eMail: weather@herray.net
Offline Slimbo1981
« Reply #727 on: January 14, 2019, 05:42:44 AM »
Hi Folks
Please can someone direct me on how to sync my Vantage vue date with of the online platforms.
I have set up an account with wow met office and weatheground but then I am stuck and have no clue what to do next to get my data loaded on to these websites. My Ip link is all set up and I can see my data on my phone whilst connected to my router. Any help will be appreciated! Thx
Offline WiFiLogger
« Reply #728 on: January 14, 2019, 08:19:06 AM »
Hi Folks
First thing to do is to reboot device after first setup to disable setup mode "WiFiLoggerSetup" network. It has to be disabled to send data through router.
Second: I assum that you know you new IP number inside home network. Use it to connect to WFL website, then navigate to SETUP| DATA EXPORT SETUP
Third find WU and WOW and type ID + passoword + set interval + click save, repeat for all platforms separatelly.
Last: WU and WOW needs some uploads to show it on web, but 1h for WU is enought.
You can go to http://YOUR_WFL_IP/debug to check what is going on.
Offline Slimbo1981
« Reply #729 on: January 14, 2019, 08:45:09 AM »
Hi, Thank you for coming back to me really appreciate it.
I did that in WU but it says my station is not active.
In WU it says password but on the website it says key?! not sure what to use.
I must be honest on Wow met office I don't even know where to start. I cannot find where to create my ID and password.
Any further help will very appreciated .thx mate
Online johnd
Offline Slimbo1981
« Reply #731 on: January 14, 2019, 08:54:48 AM »
One you sign up where do you find the details that has to be entered in the Wifi logger set up up menu? Thx
Offline WiFiLogger
« Reply #732 on: January 14, 2019, 08:54:59 AM »
Yes WU is generating ID and Key, but you have to use ID and passoword which you use to log in to WU website.
in WOW you will have ID and PIN, PIN you can change. Site ID is loiking like this: 4562c7c4-3e6b-e811-9ccb-0003febc9b2da
Offline WiFiLogger
« Reply #733 on: January 14, 2019, 08:57:03 AM »
When you will have WOW account, then you will be able to make "Site" = weather station, It will have SiteID and you will be able to make PIN for it.
You can have multilpe sites on WOW account. In WU as well, you can have planty of weather stations ID.
Offline Slimbo1981
« Reply #734 on: January 14, 2019, 09:07:28 AM »
I have now the site ID on Wow but no pin?!
Offline WiFiLogger
« Reply #735 on: January 14, 2019, 09:22:59 AM »
After login to WOW, go to MY SITES, then when you have you site info, click blue buttin EDIT SITE. Scroll down and you will find "Authentication Key", this is you PIN, just set it up then pasted to WiFiLogger.
Offline Slimbo1981
« Reply #736 on: January 14, 2019, 09:32:20 AM »
I can see that and it's an empty tab so I must populate it with a pin of my choice ans save?
Offline WiFiLogger
« Reply #737 on: January 14, 2019, 09:35:41 AM »
Probably. I have working account and Site and I don't remember how it was when was fresh, but yes you need to have this authentication key.
Offline Slimbo1981
« Reply #738 on: January 14, 2019, 09:44:34 AM »
Is there anything else that I am missing as my location still doesn't show on the map?
Also when I am connected to my IP address on my phone I always have ti switch my wifi to regain access to the internet is that normal?  When I am logged in its called Wifiloggersetup?!
Offline Slimbo1981
« Reply #739 on: January 14, 2019, 09:47:36 AM »
This is what it looks like
Offline WiFiLogger
« Reply #740 on: January 14, 2019, 10:02:17 AM »
WiFiLoggerSetup is only to establish connection with your router. To disable it you have to reboot WFL (white button, or SYSTEM and REBOOT button) You have to disable SETUP mode to start sending data by WFL.
Before disabling WiFiLoggerSetup mode, please go to SETUP| Network info, where you will be able to find new IP assigned by your router. Using this new IP you can connect from devices in router range. Laptop, phone, even TV, but inside same home network (WiFi is part of home network, home network contains also cable connections)
Offline Slimbo1981
« Reply #741 on: January 14, 2019, 11:17:33 AM »
Hi, you have been of a great help!
Any idea how to set up with weatherlink as I see they have a nice app that I would love to see my data linked to it.
Online johnd
« Reply #742 on: January 14, 2019, 11:21:04 AM »
https://www.manula.com/manuals/pws/davis-kb/1/en/topic/wfl-uploads-to-weatherlink-com
Offline Slimbo1981
« Reply #743 on: January 14, 2019, 11:23:07 AM »
By the way my WU still not working it says not responding  :-(
Offline WiFiLogger
« Reply #744 on: January 14, 2019, 11:25:51 AM »
Even if all you have made right WU needs some time for new ID. Set interval to 5 min and please wait an hour.
Check once more if ID is ok and you have used WU web password istead of station KEY
Offline Slimbo1981
« Reply #745 on: January 14, 2019, 11:43:24 AM »
And Mode enables and rapid fire enabled?
Offline WiFiLogger
« Reply #746 on: January 14, 2019, 11:45:49 AM »
:) I fogot to write you that you have to switch mode to enable on every service you like to send data to. This is simple switch on/off
mode: enable
ID - your new id
pass - web WU pass
interval 5 min
wait for sime time, about hour
Offline Slimbo1981
« Reply #747 on: January 14, 2019, 11:49:31 AM »
When configuring WU do you need to put a URL?
I feel like I am doing something wrong there!
Offline WiFiLogger
« Reply #748 on: January 14, 2019, 11:55:28 AM »
No URL is inside firmware. You need to have only active station on WU with ID, password for WU web and should work, only new ID need some time to start logging.
Offline Slimbo1981
« Reply #749 on: January 14, 2019, 12:09:39 PM »
cool thank you for your help.  I will keep you posted. Cheers
