Weather Station Hardware > Weather Radios
NOAA RADIO HARDWARE
Cutty Sark Sailor:
--- Quote from: ValentineWeather on March 30, 2017, 12:35:23 PM ---I removed my post thought we were doing a streaming setup.
--- End quote ---
Shoot... I thought what you had was cool... :eek:
tim273:
Computer: Raspberry Pi 3 with Raspbian Jessie - perfect for running 24/7 without the issues that Windows sometimes has, plus very low power.
Radio: NooElec Mini 2+ TCXO: http://www.nooelec.com/store/sdr/sdr-receivers/nesdr/nesdr-mini-2-plus.html along with the metal enclosure: http://www.nooelec.com/store/nesdr-enclosure-206.html
Antenna: Coax cable with 17 1/2 inches of the jacket stripped off (to expose 17 1/2 inches of bare inner coax wire) and mounted in the attic. I have the tools to make my own coax cable so I just put an F connector on one end and then ran the coax up to my attic with the stripped end and mounted it up there.
Adapters: To hook from the coax to the RTL SDR, I purchased two adapters, this one: http://www.nooelec.com/store/male-mcx-to-male-sma-pigtail-rg316-0-5-length.html to and this one: https://www.amazon.com/DHT-Electronics-coaxial-adapter-female/dp/B00CVTRGIC
Streaming Software: RTL SDR (https://github.com/osmocom/rtl-sdr) and Darkice (http://www.darkice.org/ and https://github.com/rafael2k/darkice)
A guide to set up the Raspberry Pi and RTL SDR is here: http://www.wxforum.net/index.php?topic=31582
In the past I've used a Reecomm R-1630 with a Raspberry Pi, Darkice and this sound card: https://www.amazon.com/Behringer-UCA202-BEHRINGER-U-CONTROL/dp/B000KW2YEI and this adapter https://www.amazon.com/gp/product/B0052A2LYG along with a pair of RCA cables. I actually found a mono 3.5mm to dual RCA splutter, it may have been at Radio Shack before they stopped selling that stuff but I can't seem to find another one like it.
For hooking the coax antenna cable to the radio antenna RCA connector, I needed one of these: https://www.amazon.com/Coaxial-Adapter-Female-Male-Style/dp/B000AAL4PA
Bonus Item:
Uninterruptible Power Supply (UPS): https://www.samsclub.com/sams/1350-battery-backup/prod8410081.ip I happen to have a Sams Club membership and saw this one day at the store. This will keep your stream up and running if there is a power outage, which of course happens when there is severe weather and people need your stream the most! You'll need to plug your computer, radio (if it's external), and router/modem into it to keep the stream going. Depending on what kind of computer you have, it will last 30 minutes to a few hours. On mine, the total load with Raspberry Pi/RTL SDR, modem and router is about 15 watts, so mine should last a couple hours or so. If you search on Amazon for UPS, you'll find quite a few to choose from.
DW7240:
Hi Tim.
You've outdone me :grin: :grin: awesome amount of information there, THANK YOU !! =D>
Lets get this listing growing !! remember, not expecting everything but the kitchen sink in your reply, as long as the radio in use is listed and has the necessary audio output (ear/headphone socket/RCA connections etc, any other info is a bonus !! \:D/
Nick. dw7240.com
tim273:
--- Quote from: DW7240 on March 30, 2017, 01:25:06 PM ---
Hi Tim.
Nick. dw7240.com
--- End quote ---
Thanks! I try to be thorough and I actually just updated it with a couple more things I forgot.
wxthomson:
--- Quote from: tim273 on March 30, 2017, 01:11:02 PM ---Computer: Raspberry Pi 3 with Raspbian Jessie - perfect for running 24/7 without the issues that Windows sometimes has, plus very low power.
Bonus Item:
--- End quote ---
Excellent information.
I may try building one of those.
[#] Next page
[*] Previous page
