Author Topic: Complete Firmware Reset of GW1100  (Read 632 times)
Offline HaraldS
« on: October 03, 2022, 01:02:33 PM »
I am replacing my GW1100 with the GW2000. How do I completely reset the GW1100 and remove all data?
« Last Edit: October 03, 2022, 03:12:41 PM by HaraldS »
Offline Gyvate
Re: Complete Firmware Reset of GW1100
« Reply #1 on: October 03, 2022, 03:59:28 PM »
two possibilities:
1. press the front button in the middle for 10-15 seconds (it has three pressing positions: left, middle, right)
2. insert a paper-clip end into the hole at the reverse side (center, between the first two slits ) for 10-15 seconds
both should result in a factory reset
Offline HaraldS
« Reply #2 on: October 03, 2022, 04:14:55 PM »
Sorry, but I do not see a front button on the GW1100, just a reset pin switch in the back.
https://shop.ecowitt.com/products/gw1100
Offline Gyvate
« Reply #3 on: October 03, 2022, 04:16:44 PM »
never mind - the one on the reverse side is enough  8-)
in the front there is this large button - RF - middle - WiFi
the middle portion of this black button
Offline HaraldS
« Reply #4 on: October 03, 2022, 04:17:43 PM »
Never knew that was a button. What does it do?
Offline Gyvate
« Reply #5 on: October 03, 2022, 06:24:08 PM »
reading the manual of the GW1100 reveals the mystery:
Offline HaraldS
« Reply #6 on: October 03, 2022, 06:27:30 PM »
I think they mean the bottom in the back.
Offline Gyvate
« Reply #7 on: October 03, 2022, 07:04:49 PM »
If you had read the manual ....
in chapter 3.1 - page 14 - it says:
3.1.2 Button functions
The black button is used for the reset mode:
Reset Mode: Hold the black button for about 5
seconds will reset the gateway to factory default
reset state. All the history data, Wi-Fi settings,
calibration and sensor labeling etc. are all lost
and need to be set again.
And a good way to find out is pressing it  \:D/ - but I'd save the calibration values and rain totals and custom server data (if any) beforehand - because, surprise - surprise, it could mean what they write ...   :evil:
Offline HaraldS
« Reply #8 on: October 03, 2022, 07:25:18 PM »
Thanks. I was too busy/lazy to RTFM.
I will try that before retiring. I also have a HP2561 setup, which the the main driver. This and the GW2000 are mainly for playing around with.
