Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Is there an easy way to look for typical humidity levels during July the past few years?
Quote from: RichieW13 on July 30, 2019, 08:20:00 PMIs there an easy way to look for typical humidity levels during July the past few years?Sure, to one extent or another. Only one problem, you're the only one who knows where "here" is.
Your Cumulus dayfile.txt will have the daily high and lows. You can view your dayfile through the Cumulus 1 Edit tab. This script uses daytime.txt which has a tab for the daily high and lows http://www.komokaweather.com/weather/betel_datasummaryCU.phpEnjoy,Paul
If you can wait a couple a days - It's just about to have a 'rebuild'.
