In the European Union both frequencies (433 and 868 MHz) are legal. 433 MHz tends to be more prone to interferences and has a lower reach (distance between sensor (array)s - therefore 868 MHz is preferable.
Misol generally only sells devices for the Asian market where the main frequency is 433 MHz (as long as a sensor and the console send/receive on the same frequency, they will work together).
It is true that amazon.de hasn't mentioned the frequency for the WS3500 (or let's say: Sainlogic haven't mentioned that on amazon.de).
I had a call with amazon.de and they sent me me a manual in which the station is described - and there it is 868 MHz (and another model with 915 MHz which is U.S.A. only and interfering with mobile networks in Europe).
The amazon.de offer is with 165 EUR more expensive than the same model (sold as WH3000SE) by froggit (140 EUR), so I'm wondering why you would want to go for the amazon.de offer.
So why don't you buy the WH3000SE from Froggit and the GW1100 + a WH51 (soil moisture) sensor from Ecowitt. GW1100 36 (USD) + WH51 (17 USD) = 53 USD + import tax (probably 20% for Slovenia, it's the VAT in SLO) = 64 USD/60 EUR.
You should order the 868 MHz models then at Ecowitt. Price-wise you will be around 200 EUR (Froggit + Ecowitt).
Froggit only would be 140 + 50 DP1500(GW1000) + 30 DP100(WH51) = 220 EUR. As you can see not a big difference. Ecowitt means waiting for about 2 weeks after purchase, Froggit inside the EU 5-7 days.
Even WS3500 from Amazon (160 EUR) + GW1000 from Misol (27 USD) + WH51 from Misol (17 USD) = 44 USD - again you are around 200 EUR and no real gain. 433 MHz is less reliable than 868 MHz (though legal).
I'd go for the Froggit + Ecowitt option: not only is it the cheapest solution but with Froggit you have a EU based seller for warranty issues - and Ecowitt are very customer friendly with warranty cases. With Misol you might have more difficulties to get hold of them if necessary.
But, after all, your choice
