Author Topic: Version .80 Temp/Hum Sensor  (Read 2093 times)
Offline CW7491
« on: January 20, 2021, 01:21:10 AM »
I’ve been told the Rainwise units use Sensirion sensors like Davis for temperature and humidity, but I noticed on their website the photo for their version .80 sensor looks to use a bead thermistor for temperature. The humidity element does not appear to be in view. Does anyone have experience with these sensors?
 https://rainwise.com/relative-humidity-temperature-sensor
Offline YugEsiwNiar
Re: Version .80 Temp/Hum Sensor
« Reply #1 on: February 10, 2021, 01:06:16 PM »
The Sensirion sensor is on the other side of that board.
Offline CW7491
« Reply #2 on: February 10, 2021, 07:50:54 PM »
Thanks for the reply. I’m not sure if you know, but is that a thermistor I see in addition to the Sensirion sensor? Do you know which Sensirion sensor?
Offline YugEsiwNiar
« Reply #3 on: February 11, 2021, 10:01:53 AM »
Needed to break out the magnifier for that one, looks like a sht-31 to me.
Offline CW7491
« Reply #4 on: February 11, 2021, 12:57:07 PM »
Thank you for looking. Interesting that they presumably use a thermistor for temperature instead of the Sensirion sensor.
Offline jgentry
« Reply #5 on: February 21, 2021, 05:01:10 PM »
The MK4 uses the SHT-35
« Last Edit: February 21, 2021, 05:05:56 PM by jgentry »
Davis Vantage Pro2 & WeatherFlow Tempest. WU: KXALJEMI2, KALJEMIS7, KFLPANAM363 & KALTHORS2. CWOP/APRS: C6353 & E6358
Offline YugEsiwNiar
« Reply #6 on: March 02, 2021, 10:38:09 AM »
The Version .80 is a MK3 item if I'm not mistaken
