Author Topic: Making a change  (Read 5356 times)
Re: Making a change
« Reply #50 on: October 12, 2020, 07:02:59 PM »
Decided to copy my old site for now.  It is a work in progress.
I did figure out:
1. how to FTP with WD.
2. How to get data from my Rainwise ip-100 to WD.
Going to add Fresh WDL tonight.
Have a rainwise cc-3000 on its way.
http://www.bsmweather.org/index.php
Freshwdl.is.not.working well
« Last Edit: October 12, 2020, 11:07:48 PM by chief-david »
Offline waiukuweather
Re: Making a change
« Reply #51 on: October 13, 2020, 04:35:50 PM »
I see you got FreshWDL working (was setup error) :)
Re: Making a change
« Reply #52 on: October 13, 2020, 08:13:56 PM »
glad I know how to spell. ](*,)
Re: Making a change
« Reply #53 on: October 17, 2020, 12:28:21 PM »
I have decided to wait on any major website changes and coding issues until Christmas. It's too difficult to do that and try to teach the same time.
I have the students submitting new website icons and logos.
And I would like to thank 92merc for the donation of a rain Gauge heater. I will get that installed in the next couple of weeks
Re: Making a change
« Reply #54 on: October 17, 2020, 09:07:56 PM »
then I grab a Jack Honey, start playing around and get this
http://www.bsmweather.org/index2.php
good so far.
Offline BrianLehan
    • Grace C Lehan Memorial Weather Station
Re: Making a change
« Reply #55 on: October 17, 2020, 10:50:07 PM »
Looks goods.
Davis Vantage Pro 2 plus
VWS 15x on Windows 7
Sarasota-Weather Template
Gr3 Radar
Re: Making a change-help connecting cc-3000
« Reply #56 on: October 22, 2020, 08:38:52 PM »
I received my RW  cc-3000.
I purchased the RS-232 model-weary of the USB like davis.
I cannot get my computer or WD or pick up the data from the cc-3000.
I know all of the boxes are checked and the light is blinking saying it is getting data.
Anything I can do to the com port to fix this?
RW has a comport tester. https://rainwise.com/cc-3000-data-logger
Nothing is in the file that it makes. Has to be a com issue on the computer end. Looks like all drivers are up to date AFAIK.
Re: Making a change
« Reply #57 on: October 24, 2020, 05:53:20 PM »
did more work on my template website.
I finally read the directions on the WD plugins and added my testtag file.
Still more work to do
but    http://www.bsmweather.org/index2.php
Question. What is the intended difference between index.php and wxindex.php
« Reply #58 on: October 25, 2020, 12:16:21 PM »
So I was thinking--IP 100 from the computer or the ethernet from a small switch.
I think I need to remove both. Restart the computer with the cc-3000 to reset the com ports.
Does that sound like the issue?
No school Friday. Rain gauge heater should go in!!!!
« Last Edit: October 25, 2020, 12:38:29 PM by chief-david »
Online PaulMy
Re: Making a change
« Reply #59 on: October 25, 2020, 12:33:20 PM »
From what I recall and according to the template install instructions it is a temporary index file while you are working to set up the template and not to interfere with your live index file.
When you've decided that the new site is to be made 'live', then use these steps to have it become the primary display.
Rename (on your local disk) wxindex.php to index.php
Re: Making a change
« Reply #60 on: November 01, 2020, 05:24:31 PM »
Since they cancelled school Friday, I had the day off...So.  I went to school.
Added a rain gauge heater
I installed a waterproof box, a plug that turns on and off with temperature. And ran a cord to plug it into an AC or heater unit on the roof.
I do not have full time access to the roof. Which does not allow me full time access to the switch to turn on the heater. So the yellow thermo cube in the black Box will turn off in Sunny weather.
Also working with Rainwise to get a cc-3000 to work. the RS-232 version did not. May go to USB
 I  wont worry about the rest of the website until Christmas break.
« Last Edit: November 01, 2020, 09:38:58 PM by chief-david »
Re: Making a change
« Reply #61 on: November 27, 2020, 10:14:13 PM »
What was that about waiting???
Going well now that I have figured out the menubar.php and that some sites do not allow them to be embedded.
looking at others sites for more ideas of pages to add (steal)
https://www.bsmweather.org/
« Last Edit: December 26, 2020, 10:14:30 PM by chief-david »
Re: Making a change
« Reply #62 on: November 28, 2020, 08:04:35 PM »
https://www.gwwilkins.org/
Holy cow do you have the pages....It will take me forever to get these done. But you have cool things.
Offline gwwilk
  • Southeast Lincoln Weather
Re: Making a change
« Reply #63 on: November 29, 2020, 07:38:21 AM »
Thanks, Chief.  I hope you can use at least some of them.
https://www.gwwilkins.org/gwwScripts.php is a direct link to my scripts page.
Regards, Jerry Wilkins
gwwilk@gmail.com
Re: Making a change
« Reply #64 on: December 01, 2020, 01:20:37 PM »
SS gauges not working well. Does have customclient.raw on the server
https://www.bsmweather.org/wxssgauges.php
https://www.bsmweather.org/customclientraw.txt
Offline the beteljuice
  • the beteljuice
    • test site
Re: Making a change
« Reply #65 on: December 01, 2020, 05:29:14 PM »
Your scripts are being told to load from the wrong place.
Looks like you've put (as a var) 'customclientraw.txt' in the wrong place.
Re: Making a change-Mobile site
« Reply #66 on: December 23, 2020, 09:21:40 AM »
anyone have a good mobile page I can copy/steal ?????
« Last Edit: December 23, 2020, 09:39:00 AM by chief-david »
  • the beteljuice
    • test site
Re: Making a change
« Reply #67 on: December 23, 2020, 10:51:28 AM »
You still haven't changed the var for the location of the SS scripts ?
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/steelseries_tween.min.js”. wxssgauges.php:577:1
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/language.min.js”. wxssgauges.php:581:1
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/gauges.js”. wxssgauges.php:582:1
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/windrose.js”. wxssgauges.php:586:1
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/RGraph.common.core.min.js”. wxssgauges.php:587:1
Loading failed for the <script> with source “https://www.bsmweather.org/wxgraphic/customclientraw.txtscripts/RGraph.radar.min.js”. wxssgauges.php:588:1
Re: Making a change
« Reply #68 on: December 23, 2020, 11:12:23 AM »
hopefully today-I have to Teamviewer in to get customclientraw to the right place
and I think I may have files in the wrong places
got this so far
https://www.bsmweather.org/gauges-ss-basic.htm
« Last Edit: December 23, 2020, 05:22:15 PM by chief-david »
Re: Making a change-Question
« Reply #69 on: December 27, 2020, 11:09:27 AM »
My main page current conditions shows Partly cloudy and it is snowing.
How can I change this to  reflect what is happening at Crystal, MN airport.
Is it Weather Display configuration
       my coding
       both?
same with the icon on the banners.
https://bsmweather.org/
BTW-my old school station site has been unoperational for about a month. What a shame.
« Last Edit: December 27, 2020, 11:11:42 AM by chief-david »
Offline 92merc
  • BismarckWeather.net
Re: Making a change
« Reply #70 on: December 27, 2020, 11:47:22 AM »
In WD, go into control panel,
FTP and Connections METAR/NOAA
METAR Download Tab.
turn it on and find your airport in the list.  Set the download times.
Re: Making a change
« Reply #71 on: December 27, 2020, 01:08:52 PM »
still nothing ...ugh
now better-I will keep an eye on it.
Chiefs game is on
« Last Edit: December 27, 2020, 01:14:34 PM by chief-david »
Offline 92merc
Re: Making a change
« Reply #72 on: December 27, 2020, 02:51:41 PM »
I saw this in WD's FAQ section too:
Why isn't the current weather icon updating by its self according to the METAR station?
Make sure that under the list of METAR stations that "use this METAR for local sky conditions (and weather underground)" is checked. Also make sure that the box next to that has the name of the METAR station that you want to be displayed. Example KEWR.TXT
Re: Making a change
« Reply #73 on: December 27, 2020, 02:59:07 PM »
I did that now.   10 years, still learning this stuff.
Offline 92merc
Re: Making a change
« Reply #74 on: December 27, 2020, 03:24:52 PM »
Did that work?
No worries, it's all new to me too.   Once I set it, I forget it.
