Author Topic: UV at this time of year?  (Read 1822 times)
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« on: January 22, 2022, 07:54:56 AM »
Hi folks, it looks like my UV stopped recording on the 9th of November last year, should there be at least something a this time of year in full sunlight?
Kind regards
Bashy
Re: UV at this time of year?
« Reply #1 on: January 22, 2022, 08:28:16 AM »
Here is my UV for yesterday: Yest.    1.4 index at 1:26pm
Sometimes when I have snow on the sensors the readings are low as one would expect.
So yes, I do get both UV and Solar readings in Winter, here in northern Michigan USA.
Nothing is showing right now due to the fact that it is overcast and Sunrise was just 20 minutes ago. You can check this plot later and you should see both UV and Solar. It might not register a lot due to the forecast of overcast and snow for today. It was sunny yesterday when the UV amount of 1.4 was recorded.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #2 on: January 22, 2022, 08:31:00 AM »
I certainly get UV of one-ish on sunny winter days at my latitude.
Offline Bashy
    • Breckland Weather
« Reply #3 on: January 22, 2022, 08:57:24 AM »
Dammit, looks like my uv sensor has given up then :(
5 years is all it lasted, same with my soil/leaf station board, that's a lot of money up the swanny, although, Davis support say they swap out as long as the leaf Station isn't over 5 years, but I don't think the UK supplier likes that idea :(
« Last Edit: January 22, 2022, 09:12:25 AM by Bashy »
Kind regards
Bashy
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #4 on: January 22, 2022, 05:44:19 PM »
Getting UV here as well on my VPro 2 in the dead of winter. Have you checked the UV's plug in the ISS ? Pull it and clean it to make sure you are getting a good connection. Is it "dashed out" on the display ? Have you restarted your console/Envoy or whatever has the data logger ? All the years hanging here and other hardware forums and a failed UV sensor is kinda rare.
Offline Aardvark
    • turned off
« Reply #5 on: January 22, 2022, 08:18:31 PM »
I get about the same reading. the sun angle striking the sensor is not direct so the low readings.   I suspose if one wanted  to rotate the sensor toward the sun , perhaps a greater reading.    Oddly a person could get a sunburn in winter, before the froze to death.
Online Mattk
« Reply #6 on: January 22, 2022, 09:50:54 PM »
Hearing of a failed Davis UV sensor is a rare one but they are rather a very expensive bit of kit compared to any of the Davis standard sensors
Offline Bashy
    • Breckland Weather
« Reply #7 on: January 22, 2022, 10:58:49 PM »
Hi guys, its not reading -- just 0.0, for similar full sunny days last January (2021) i was seeing 0.7 max UV, max solar for that day was 420, the other day it hit 470 with UV 0.0, i believe it doesn't register till 0.5, so at the very least i should see 0.5 at 470
Jan last year
 21 02:36hrs ,ET :1.0 mm  ,420.0 W/m²  ,0.7 uv
 22 07:00hrs ,ET :0.5 mm  ,322.0 W/m²  ,0.7 uv
Similar days this Jan
 19 01:54hrs ,ET :0.6 mm  ,436.0 W/m²  ,0.0 uv
 20 00:24hrs ,ET :0.3 mm  ,473.0 W/m²  ,0.0 uv
 21 02:36hrs ,ET :0.3 mm  ,429.0 W/m²  ,0.0 uv
Granted, i cannot rule out bird doody, but that is very unlikely because they do not perch up on there, they stick to the older OS anemometer that's a little higher up, not once have a seen a bird on the Davis, many times a day i see doves or pigeons on the OS, i set it up that way so they will leave the Davis alone :)
« Last Edit: January 23, 2022, 02:26:46 AM by Bashy »
Kind regards
Bashy
Offline doubleohwhatever
« Reply #8 on: January 23, 2022, 12:40:06 AM »
Yep, your sensor is either covered in poop or dead (could be a connection issue - corrosion, etc). We've had some very dim and overcast days the last week and mine has been behaving as it should:
https://griffinparkweather.com/week.html
Offline Bashy
    • Breckland Weather
« Reply #9 on: January 23, 2022, 03:31:26 AM »
It could be poop but its unlikely, the bird would have to perch on the top of the pole, never seen them do that in all my time here, it looks like this was the last day of any UV reporting
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #10 on: January 23, 2022, 06:45:07 AM »
I have checked the connection and it looks OK as far as I can tell, can the board be rebooted by removing the battery and solar? Or does it not work that way?
Looking back to this time last year, i only see 2 days that recorded any UV, 22nd and the 23rd of January, as i mention above..
I will keep an eye on it as it might be that i tightened the guy lines in such a way that the solar and UV are tilted off kilter a little, i have loosened the back guy (North side) and tightened the south side some, will see how that goes when the sun finally shows itself again, hopefully, tomorrow...
« Last Edit: January 23, 2022, 08:01:09 AM by Bashy »
Kind regards
Bashy
Offline Garth Bock
« Reply #11 on: January 23, 2022, 08:34:26 AM »
Sometimes unplugging and replugging the connector at the ISS end will do something. There is no reboot of the ISS board that has ever been mentioned. I was referring to reboot or restarting your console/Envoy or whatever receives your data. I had an old console that would freeze up about twice a year and pulling batteries would cure it (a later firmware update took care of it). If you have power cycled your data receiving end then the dirty bird scenario is the next thing.
Offline Bashy
    • Breckland Weather
« Reply #12 on: January 23, 2022, 08:56:56 AM »
Thanks, I didn't think so re board, I am using WLL as the receiver, I will reboot it as well, thanks, will see how it goes...
Kind regards
Bashy
Offline archae86
    • LynxStoll weather
« Reply #13 on: January 23, 2022, 09:09:53 AM »
Taking your reports in aggregate I think that your UV sensor has suffered a massive loss of sensitivity. Two additional contributing factors are that your location and the time of year mean that the real UV available is not so very much right now, and that Davis converts anything that would be reported as less than 0.5 to 0.0.
Probably it is not actually dead.
My first Davis UV sensor suffered a very considerable loss of sensitivity.  At age five years I activated a 1.40 calibration factor to attempt to compensate for the degradation to that point.  A year later when I called them to inquire about the options for getting it recalibrated they offered me a hot swap on refurbished replacement at a considerably lower price than I would have paid for new sensor. That replacement does not seem yet to have degraded at all in four years. So I don't think the sensitivity loss is a constant rate per year, nor do I think that all individual sensors suffer it exactly the same way. It seems to me that you got unlucky on that matter and that looking around your system for things to tinker with won't get you anywhere.
Of course, since I live in Albuquerque New Mexico, I did not see long months of 0.0, even with my degraded sensor, which was probably less degraded than yours now is.
Offline Bashy
    • Breckland Weather
« Reply #14 on: January 23, 2022, 09:21:12 AM »
I fear you might be right, sadly Davis do not offer the same deal(s) for customers outside the US.
Like we already know uv for the UK at the is time of year isn't much at all and I did have to add a offset fron the get go, those 0.7's you see above should actually be 0.5,cant remember how much I added, just checked, it was 30%,now that could be because the top of the mast may not have been level, hard to do with 6 guy lines and trying to eye it up front he bottom of the mast (10m), it is possible that the last time I touched the guy lines, I may have drgeed to more Northolt if that makes sense, I'm hoping that's what I did, but having said that, I do not think I have touched the mast in well over a year, I think it was 2020 the last time, I could be wrong mind but I don't remember touching it last year, I was going too to repka E the fan but I kept putting it off. Only time will tell, hoping for some sun tomorrow, I have rebooted the WLL now, I've also dragged the mast more southerly, so fingers crossed, only think I can do now is bring it down and hit it with some rubbing alcohol, that's Ok for the sensors isn't it?
Kind regards
Bashy
« Reply #15 on: January 23, 2022, 11:35:55 AM »
I know very little about UV but my VP2 Plus (2018) seems to be ok and does report UV index from 0.1 and UV Dose MEDs from 0.01
http://www.komokaweather.com/cumulusmx/trends.htm#solar
and http://www.komokaweather.com/cumulusmx/historic.htm#solar and select All
VP2 Plus from May 2018 and before that Sunshine hours was from B-L Sunrecorder
Offline Bashy
    • Breckland Weather
« Reply #16 on: January 23, 2022, 11:45:19 AM »
I think ya meant 0.5, youre in Canada I see, are you higher up the globe than the UK or lower?
Kind regards
Bashy
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #17 on: January 23, 2022, 11:51:38 AM »
London is about 51. In Ontario South we are mid 40's
Offline Bashy
    • Breckland Weather
« Reply #18 on: January 23, 2022, 11:54:15 AM »
Thanks so you're higher up, so in effect I should be recording higher uv than you if both are setup correctly, I can gaurrantee that mine is level at 10m it was at the bottom of the mast but the guy lines may have pulled it off kilter, bloody hard to know at that height...
Kind regards
Bashy
« Reply #19 on: January 23, 2022, 12:18:24 PM »
We are
komoka village weather Latitude N 42° 57' 36"    Longitude W 81° 26' 18"    Elevation 817 ft [/font][/color]
Using WLLive and in WL.com it shows UV Index from 0.1
Offline archae86
    • LynxStoll weather
Rubbing alcohol not OK
« Reply #20 on: January 23, 2022, 02:18:09 PM »
Not according to Davis.
The manual I downloaded sometime for installation of the solar and UV sensors contains this direction:
"Hold the sensor body with the white diffuser pointed upward.  Do not touch the diffuser.  If you do, clean it after mounting using a cotton swab and ethyl alcohol.  Do no use rubbing alcohol."
Several of us have reported here using Everclear as a commercially available 95% ethanol preparation for this purpose.  However one person told us he was advised by Davis support that was not OK either, as it had an undesired contaminant.
Here in the US, the problem is that alcohol regulations get in the way of sale of simple ethanol to customers who are not laboratories, or places using it as an input ingredient.  I found someone selling on eBay from Bulgaria, so I affectionately call it my "Bulgarian booze".
Whether any of this actually matters I don't know.  As your sensor is already not working properly (apparently), I don't think you'd be risking much.  But the party line is not to use rubbing alcohol--specifically and by name.
Offline mcrossley
    • Wilmslow Astro
« Reply #21 on: January 23, 2022, 05:13:42 PM »
Thanks so you're higher up, so in effect I should be recording higher uv than you ...
eh? mid 40's puts them south of Paris. Quite a bit south of us.
Offline Bashy
    • Breckland Weather
« Reply #22 on: January 27, 2022, 11:59:02 AM »
Solar hit 450 today and no uv showed at all, 0.0
I took the DJI Mini 2 up earlier to see if I could see out and I saved these images from the video, to me, they both look clean?
Kind regards
Bashy
« Reply #23 on: January 27, 2022, 12:19:09 PM »
My guess would be either corrosion has formed on the connector or something inside the sensor died. Likely the latter but I'd check the connector before ordering a replacement just in case.
Offline Bashy
    • Breckland Weather
« Reply #24 on: January 27, 2022, 03:23:31 PM »
The connector is fine as far as I can see, no moisture on there either, it's quite clean all round in there.
I dont think I will get another one, over £700 worth of devices up the swanny. Having seen that someone a mile away from me has am ecowitt setup and their readings are pretty much identical to mine at a fraction if the cost, I would be foolish to stick with Davis, I will let this Davis die and I the mean time build up an ecowitt setup. I was foolish to think that Davis would last me longer than it has. I am also disappointed that the UK customers do not get the same treatment as our US friends, US get replacementd as long as its not over 5 years old, UK pays more and gets diddly squat in return. Plus, the Weatherlink is also a let down. So as it stands I am done with Davis.
Kind regards
Bashy
