Web Weather => Weather Website PHP/AJAX scripting => Custom Website Templates => Topic started by: txweather.org on April 03, 2019, 01:56:08 PM
Title: Lightning Script
Post by: txweather.org on April 03, 2019, 01:56:08 PM
Has the BO from lightingmaps.org has been updated?
I have try to use it in the past and works ok for the most part but with every installation it seems to quit working at some point.
Also is there something better or new out there?
Title: Re: Lightning Script
Post by: saratogaWX on April 03, 2019, 04:25:36 PM
Looks like you're using my BOmaps script set for https://www.txweather.org/wxbo.php -- BTW.. there's no 'Radar' involved .. the map is a static map on which the strike data from Blitzortung.org is overlaid.
I've not updated the script set since 04-Nov-2018 (BOmaps V1.05) when the format of the JSON returns changed.  I have found that there are times when blitzortung.org data becomes unavailable (either due to BO server issues, or internet connectivity issues), but recovery should be automatic with the scripts when the data becomes available again.
Post by: txweather.org on April 03, 2019, 04:30:09 PM
Thanks Ken!
Post by: Cutty Sark Sailor on April 03, 2019, 05:55:13 PM
http://sferics.us/nastat/   one implementation experiment...
Post by: txweather.org on April 03, 2019, 07:41:07 PM
That looks awesome Cutty! When you are ready to share the code, Please let me know and ill be glad to be your first tester! :P
Post by: pimohdaimaoh on September 20, 2019, 04:40:49 AM
I already have mySystem Blue from Blitzurtung and I want to use this BOmaps. Can I use this for philippine maps?
How should I do it?
Regards
-Mike-
Post by: Cutty Sark Sailor on September 20, 2019, 09:56:12 AM
Mike, Ken's scripts are fully annotated, and this package from Saratoga Weather has a well written "Read Me', so the rest is up to you... the Map images must be created by you, using the Map generator standards from Blitzortung, the online generator is located on Blitzortung at http://en.blitzortung.org/map_generator.php (http://en.blitzortung.org/map_generator.php)
If you're referring to the LightningMaps.org script "My Blitzorting"... I would remind that, because of advanced server proceessing, etc, over the last few years, that script is no longer supported, or being developed...
...however the Ken True scripts are not affected, as he maintains them with a Hawk's Eye...  :thumbsup:
At the moment, however, last I heard, Ken is out of country ons some big ship in the Northern Latitudes', hopefully back at base around October 1st...
 UU
 Mike
Post by: pimohdaimaoh on September 21, 2019, 01:58:46 AM
If you're referring addiditonaly to the LightningMaps.org script "My Blitzorting"... I would remind that, because of advanced server proceessing, etc, over the last few years, that script is no longer supported, or being developed... however the Ken True scripts aare not affected, as he maintains them with a Hawk's Eye...  :thumbsup:
 UU
 Mike
Hello,
Thank you for the guide and clarification, I will proceed to make my maps then
Regards
-Mike-
