Author Topic: Ecowitt Fineoffset-WS90 added to RTL_433 SDR Application  (Read 355 times)
Offline Jonesy
« on: May 30, 2023, 07:37:11 AM »
I see that the WS90 sensor array can now be received by the RTL_433 software.
It's pre-release at the moment with some data fields still to be defined, some of which I expect are firmware version and extra rain data.
I used command line;
>rtl_433.exe -M Level -R 244 -Y minmax
and received;
model     : Fineoffset-WS90                        ID        : 65949a
Battery   : 1.000        Battery Voltage: 3280 mV  Temperature: 11.1 C       Humidity  : 99 %          Wind direction: 327       Wind speed: 0.6 m/s       Gust speed: 0.7 m/s       UVI       : 0.0           Light     : 0.0 lux
Flags     : a9           Total Rain: 1548.7 mm     Supercap Voltage: 4.9 V   Extra Data: 2f263c7f31c31fcfbab900007b              Integrity : CRC
Modulation: FSK          Freq1     : 433.9 MHz     Freq2     : 434.0 MHz
RSSI      : -0.1 dB      SNR       : 31.3 dB       Noise     : -31.4 dB
