When resetting the console the following messages appear. Unfortunately, typing something does neither get echoed nor does it show any reaction. Maybe someone here has an idea how to get into interaction. I hoped to find a login shell, but no success so far.
Terminal ready
DDR V2.09 20171109
In
DDR3
300MHz
BW=16 Col=10 Bk=8 Row=15 CS=2 Die BW=16 Size=1024MB
OUT
Boot1 Release Time: Jul 25 2018 09:49:51, version: 2.52
ChipType = 0xb, 2299
bootrom_ver: 56323030, ChipType:12
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
&????,32ize=7456MB
SdmmcInit=0 1
StorageInit ok = 117174
GPT part: 0, name: uboot_a, start:0x4000, size:0x2000
GPT part: 1, name: uboot_b, start:0x6000, size:0x2000
GPT part: 2, name: trust_a, start:0x8000, size:0x2000
GPT part: 3, name: trust_b, start:0xa000, size:0x2000
GPT part: 4, name: misc, start:0xc000, size:0x2000
GPT part: 5, name: resource, start:0xe000, size:0x8000
GPT part: 6, name: kernel, start:0x16000, size:0x10000
GPT part: 7, name: dtb, start:0x26000, size:0x2000
GPT part: 8, name: dtbo_a, start:0x28000, size:0x2000
GPT part: 9, name: dtbo_b, start:0x2a000, size:0x2000
GPT part: 10, name: vbmeta_a, start:0x2c000, size:0x800
GPT part: 11, name: vbmeta_b, start:0x2c800, size:0x800
GPT part: 12, name: boot_a, start:0x2d000, size:0x20000
GPT part: 13, name: boot_b, start:0x4d000, size:0x20000
GPT part: 14, name: backup, start:0x6d000, size:0x38000
GPT part: 15, name: security, start:0xa5000, size:0x2000
GPT part: 16, name: cache, start:0xa7000, size:0xc0000
GPT part: 17, name: system_a, start:0x167000, size:0x300000
GPT part: 18, name: system_b, start:0x467000, size:0x300000
GPT part: 19, name: metadata, start:0x767000, size:0x8000
GPT part: 20, name: vendor_a, start:0x76f000, size:0xc0000
GPT part: 21, name: vendor_b, start:0x82f000, size:0xc0000
GPT part: 22, name: oem_a, start:0x8ef000, size:0x40000
GPT part: 23, name: oem_b, start:0x92f000, size:0x40000
GPT part: 24, name: frp, start:0x96f000, size:0x400
GPT part: 25, name: userdata, start:0x96f400, size:0x520bdf
no find partition:uboot.
LOADER Check OK! 0x60000000, 605116
tag:TOS error,addr:0x4000
hdr 632c77e0 + 0x0:0x44414f4c,0x20205245,0x00000000,0x00000000,
TOS Check OK! 0x68400000, 840222
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-372-g9a9308d-dev #2 Thu Dec 6 07:03:01 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.2
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x60000000
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
U-Boot 2017.09 (Jul 22 2022 - 15:32:28 +0800)
Model: Rockchip RK3126 Evaluation board
DRAM: 1010 MiB
Relocation Offset is: 3dd76000
Using default environment
dwmmc@1021c000: 0
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
mmc0(part 0) is current device
Load FDT from boot_b part
DTB: rk-kernel.dtb
boot mode: None
android_fdt_overlay_apply: failed to get boot part info, ret=-1
Using kernel dtb
PMIC: RK8160 (on=0x26, off=0x00)
vdd_arm 1100000 uV
vdd_logic 1100000 uV
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.167 (itrex@bymskhost003) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #2 SMP PREEMPT Thu Mar 9 12:27:25 +03 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Rockchip RK3126 WB801 board
[ 0.000000] earlycon: Early serial console at MMIO32 0x20068000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x88000000, size 24 MiB
[ 0.000000] Reserved memory: initialized node region@88000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ef693000 s23884 r8192 d21172 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 256832
[ 0.000000] Kernel command line: androidboot.storagemedia=emmc androidboot.mode=normal dm="1 vroot none ro 1,0 3095928 verity 1 PARTUUID=74440000-0000-4519-8000-6cf600004eeb PARTUUID=74440000-0000-4519-8000-6cf600004eeb 4096 4096 386991 386991 sha1 f3d00226036464d56a2d0b72278850397778e2a6 f1874cacb490389661733c23cb6b33dfdbcfc00d01a4a27c87a5c1fa922ab25f 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=74440000-0000-4519-8000-6cf600004eeb fec_roots 2 fec_blocks 390040 fec_start 390040" root=/dev/dm-0 androidboot.vbmeta.device=PARTUUID=c2430000-0000-4c5d-8000-527000007986 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3264 androidboot.vbmeta.digest=6c191450d6512e9e97e274c41858afcdc98d400f22937e8016f420129b226a33 androidboot.veritymode=enforcing androidboot.verifiedbootstate=orange skip_initramfs androidboot.slot_suffix=_b androidboot.serialno=6313U22500213407 console=ttyFIQ0 androidboot.baseband=N/A androidboot.wificountrycode=US androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 firmware_class.path=/vendor/etc/firmware init=/init rootwait ro init=/init buildvariant=user earlycon=uart8250,mmio32,0x20068000
[ 0.000000] device-mapper: init: will configure 1 devices
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 948604K/1034240K available (10240K kernel code, 1057K rwdata, 3868K rodata, 1024K init, 2134K bss, 44676K reserved, 40960K cma-reserved, 241416K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b00000 (11232 kB)
[ 0.000000] .init : 0xc1000000 - 0xc1100000 (1024 kB)
[ 0.000000] .data : 0xc1100000 - 0xc12086f8 (1058 kB)
[ 0.000000] .bss : 0xc120a000 - 0xc141fa18 (2135 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008417] Switching to timer-based delay loop, resolution 41ns
[ 0.016356] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.027161] pid_max: default: 32768 minimum: 301
[ 0.032136] Security Framework initialized
[ 0.036462] SELinux: Initializing.
[ 0.040251] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.047241] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.055766] Initializing cgroup subsys memory
[ 0.060465] Initializing cgroup subsys freezer
[ 0.065243] CPU: Testing write buffer coherency: ok
[ 0.070968] /cpus/cpu@f00 missing clock-frequency property
[ 0.076804] /cpus/cpu@f01 missing clock-frequency property
[ 0.082578] /cpus/cpu@f02 missing clock-frequency property
[ 0.088366] /cpus/cpu@f03 missing clock-frequency property
[ 0.094173] CPU0: update cpu_capacity 430
[ 0.098390] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.104561] Setting up static identity map for 0x60100000 - 0x60100058
[ 0.142144] CPU1: update cpu_capacity 430
[ 0.142157] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.152219] CPU2: update cpu_capacity 430
[ 0.152231] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.162329] CPU3: update cpu_capacity 430
[ 0.162341] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.162499] Brought up 4 CPUs
[ 0.196506] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.203112] CPU: All CPU(s) started in SVC mode.
[ 0.210181] devtmpfs: initialized
[ 0.240069] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.248887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.259255] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.268650] pinctrl core: initialized pinctrl subsystem
[ 0.276199] NET: Registered protocol family 16
[ 0.285746] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.306516] cpuidle: using governor ladder
[ 0.320925] cpuidle: using governor menu
[ 0.325159] Registered FIQ tty driver
[ 0.357004] console [pstore-1] enabled
[ 0.361466] pstore: Registered ramoops as persistent store backend
[ 0.368045] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[ 0.376153] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.384638] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.466022] iommu: Adding device 10104000.vpu_service to group 0
[ 0.472496] iommu: Adding device 10108000.iep to group 1
[ 0.478221] iommu: Adding device 1010e000.vop to group 2
[ 0.485962] SCSI subsystem initialized
[ 0.490460] usbcore: registered new interface driver usbfs
[ 0.496461] usbcore: registered new interface driver hub
[ 0.502281] usbcore: registered new device driver usb
[ 0.509204] media: Linux media interface: v0.10
[ 0.514141] Linux video capture interface: v2.00
[ 0.519335] pps_core: LinuxPPS API ver. 1 registered
[ 0.524619] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.534306] PTP clock support registered
[ 0.540871] Advanced Linux Sound Architecture Driver Initialized.
[ 0.548499] Bluetooth: Core ver 2.21
[ 0.552427] NET: Registered protocol family 31
[ 0.557138] Bluetooth: HCI device and connection manager initialized
[ 0.563880] Bluetooth: HCI socket layer initialized
[ 0.569034] Bluetooth: L2CAP socket layer initialized
[ 0.574263] Bluetooth: SCO socket layer initialized
[ 0.581292] rockchip-cpuinfo cpuinfo: Serial : 0df464036d285764
[ 0.591409] clocksource: Switched to clocksource arch_sys_counter
[ 0.702476] rockchip ion idev is NULL
[ 0.706448] rga 1010c000.rga: rga ion client create success!
[ 0.712861] rga: Driver loaded successfully
[ 0.717778] rga: Module initialized.
[ 0.725307] NET: Registered protocol family 2
[ 0.731095] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.738736] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.745715] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.752562] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.758893] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.765944] NET: Registered protocol family 1
[ 0.786944] Freeing initrd memory: 9396K
[ 0.795064] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.809622] audit: initializing netlink subsys (disabled)
[ 0.815508] audit: type=2000 audit(0.633:1): initialized
[ 0.833422] VFS: Disk quotas dquot_6.6.0
[ 0.837905] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.847438] Registering sdcardfs 0.1
[ 0.851912] fuse init (API version 7.23)
