Author Topic: If you have weatherwizz. What do you use it with?  (Read 956 times)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« on: March 26, 2023, 03:13:24 PM »
I am thinking of signing up with weatherwizz. But I was kind of worried that I will never use it for its full potential.
So my question is. IF you have weatherwizz how do you use it? With a old tablet stuck on a wall? living room TV?
Thanks!
Anthony
Offline stevenh
Re: If you have weatherwizz. What do you use it with?
« Reply #1 on: March 28, 2023, 06:54:25 AM »
I'm using Weatherwizz.
I'm running it on 15" monitors, wall mounted.
Using Rpi's to drive the monitors. For the money, it is well worth the price for the ease of setup.
Changes take seconds to do!
« Last Edit: March 28, 2023, 08:10:03 AM by stevenh »
  • Hi there!
« Reply #2 on: March 28, 2023, 09:22:32 AM »
Thanks for the info. That would be a nice idea. did you do anything special with the Rpi to get them setup?
thanks again!
Anthony
Offline stevenh
« Reply #3 on: March 28, 2023, 09:39:10 AM »
I loaded the latest OS from Raspberry Pi Imager.
I had 4 RPi's that were tv streamers no longer in service.
Two were too old to run Chromium which is all you need to display Weatherwizz. I did create a tinyurl.com for shorten the URL.
On the older two I did try different images but gave up.
One of them, I wrote a couple of bash scripts to load two tabs in chromium. Wizz on one and NOAA https://water.weather.gov/ tide gauge on the other.
In the script I send a ctrl-tab to switch the pages displayed, --kiosk mode in chromium.
But there is an issue, that I haven't been able to figure out. The baro and wind graphs don't refresh and are blank.
If I also add a ctrl-F5 to refresh the wizz page, it displays the graphs.
This seems to be a chromium issue as switching tabs on the desktop works fine.
  • Hi there!
« Reply #4 on: March 28, 2023, 09:52:21 AM »
Thanks! I am doing a fresh Raspberry OS install now. Now I will have a use for the old pi that I have.
thanks again! (I may just keep weatherwizz now)
Anthony
Offline blizzardof78
    • Ohio Weather
« Reply #5 on: June 18, 2023, 11:49:11 AM »
I'm seriously thinking of downloading this program to my "Weather Computer" and running it. I currently upload to WU with WUHU but I understand that it is not supported with this program. If I'm able to get it to work the way I want then I'm cutting out the feed to WU. So if I have my Davis Vue feeding into my computer and then attempt to run WW will it display my data? I'm too computer illiterate to understand all of this jargon lol.
