Author Topic: GW1000 Direct Configuration option  (Read 479 times)
Offline Mandrake
« on: June 11, 2021, 03:51:17 AM »
Just in from Ecowitt...
https://www.ecowitt.com/shop/forum/forumDetails/212
This route allows you (assuming you know the allocated IP address of your GW1000 from your router) to configure via WSView
This option is useful if you are having trouble finding the device on WSview in the first place to configure
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Gyvate
Re: GW1000 Direct Configuration option
« Reply #1 on: June 11, 2021, 08:25:42 AM »
This seems to be for the case only, where/when the pairing with the router (Ecowitt term: router configuration) was already successful (which usually also is done via WSView - or with the Windows-Router-Connect tool) and the device doesn't appear in the device list. Or am I misreading the (Ecowitt) forum post ?
Offline Mandrake
« Reply #2 on: June 11, 2021, 10:02:18 AM »
Sorry, yes badly worded on my part!
If after initial setup (wifi connection) you still cannot see the GW1000 in the WSView app then follow this process!
G1ZFO
Offline Gyvate
« Reply #3 on: June 11, 2021, 10:43:25 AM »
No problem  8-) - I'll be integrating this and the Windows Connect tool option into the WiFi connection thread.  :-)
So we have as many options as possible available in one place for those in need to look up.  8-)
Offline Gyvate
« Reply #4 on: June 12, 2021, 08:30:05 AM »
