Author Topic: WS80 or WS68 for snowy conditions?  (Read 315 times)
Offline Jeje2
« on: October 07, 2021, 10:19:23 AM »
Seen postings by several members (Gyvate, solartempest, wardie, ...)  of WS80 covered in snow while looking information on the unit, as it seems quite interesting...
But of course while top is covered in snow the sensors on top are not giving much usefull information and the heater offsets the outside temp measurement slightly.
So considering that the anemometer would not have ideal placement conditions by far (to much high trees and a house)  -- would a WS 68 with wind speed cups and wind wane be be better than the WS80 Ultrasonic system, or?
(I currently have an ols HeavyWether weather station with wind speed cups and wane and it do give me readings on local conditions)
Looking for recommendations from users with experience in snowy conditions...
Ecowitt:
  • GW1102 Wi-Fi Weather Station with Solar Powered Wireless Anemometer, UV & Light Sensor, Self-Emptying Rain Collector
    • GW1100 Ecowitt Wireless Weather Station Gateway
    • WS68 Wireless Solar Powered Anemometer with Light & UV Sensor
    • WH40 Wireless Self-Emptying Rain Collector Rainfall Sensor
    • Outdoor Temperature and Humidity Sensor
  • WH31 Multi-Channel Temperature and humidity Sensor (8 pcs)
  • WH51 Wireless Soil Moisture Sensor
  • WH45 Indoor CO2 PM2.5 PM10 Temperature and Humidity 5-in-1 Air Quality Sensor
  • WH57 Outdoor Wireless Lightning Detection Sens
Offline Rover1822
Re: WS80 or WS68 for snowy conditions?
« Reply #1 on: October 07, 2021, 11:02:49 AM »
Tough call, I have had my cups freeze in place with freezing rain and other conditions. I don't have a WS80, nor do I get a lot of snow which would effect either in my estimation.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Gyvate
« Reply #2 on: October 07, 2021, 11:03:23 AM »
The solar sensor of a WS68 can also be covered by snow - maybe not as easily as with a WS80.
And I'm not using the WS80 temperature readings. So the little temp fluctuations when the heater is on do not matter to me.  I have a separate WH32(-EP) outdoor temperature sensor in a more appropriate place for outdoor temperature readings. The WS80 is positioned for optimal wind readings.
