Author Topic: Ambient Weather Station Beta Testers needed :)  (Read 9700 times)
Offline SnowSentry
    • WeatherWizz
Re: Ambient Weather Station Beta Testers needed :)
« Reply #175 on: August 12, 2021, 06:24:54 PM »
14 km away
What does the 14 mean under the lightning bolt?
Offline funsutton
    • Weather Underground
« Reply #176 on: August 12, 2021, 06:27:53 PM »
Ah, no wonder it doesn't match my data. We use miles here in US.
Also, date format is different too (08/12/2021)
14 km away
Offline SnowSentry
    • WeatherWizz
« Reply #177 on: August 12, 2021, 07:54:36 PM »
Depending on how you are connecting, if you are using Cumulus or custom api, you will need to modify the parameter to send that data in the format you want it displayed.  For example, for US date you can modify the URL string to be
lt=<#LightningTime format="MM-dd-yyyy HH:mm:ss">
for the distance, the URL has &ls=<#LightningDistance>  Maybe someone knows how to change this from km to miles?
Offline funsutton
« Reply #178 on: August 12, 2021, 08:11:01 PM »
I'm using the customized server on my ambient console to send the data.
Offline Gyvate
« Reply #179 on: August 12, 2021, 08:20:41 PM »
that would be the distance to/of the last strike
Offline Gyvate
« Reply #180 on: August 16, 2021, 04:52:09 AM »
Possible that your server got stuck somehow  ? My two stations keep on posting but the data displayed is stalled.
FBDYSOLGQP & KKNHVXWQUB.
Happened/started some time this morning between 04:00 and 08:00 CEST
Offline SnowSentry
    • WeatherWizz
« Reply #181 on: August 16, 2021, 05:14:27 AM »
Let me check that out.
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« Reply #182 on: August 16, 2021, 05:15:59 AM »
Hi!
I can confirm - station is still sending but no change on the page anymore.
Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #183 on: August 16, 2021, 05:33:42 AM »
Thanks guys, I am looking into the problem.
Hi!
Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #184 on: August 16, 2021, 06:19:08 AM »
Should be resolved now, quick refresh of your dash should bring it back if it has now already come back online itself.
Offline Gyvate
« Reply #185 on: August 16, 2021, 07:03:27 AM »
working again  [tup] - thanks !
Offline SnowSentry
    • WeatherWizz
« Reply #186 on: August 19, 2021, 11:03:02 PM »
Who doesn’t like a good throwback to retro displays 😊
Offline SnowSentry
    • WeatherWizz
« Reply #187 on: October 02, 2021, 02:06:02 AM »
Hey there!
I wanted to share some big news.
Over the past few months, we've been busy adding new features and dashboard themes to WeatherWizz to give you lots more things to play with :-)
And now, for Patrons, all new customizable dashboard themes have arrived on WeatherWizz! Choose from a range of styles. Select which sensors you want displayed. Even choose where you want those sensors.
Checkout the designer in youtube
https://www.youtube.com/watch?v=5x85f2Bmdso
Offline SnowSentry
    • WeatherWizz
« Reply #189 on: October 09, 2021, 04:36:40 PM »
appears to work only with Windows
Can you explain what you mean by only works with windows.   Perhaps you could tell us what device you are using?
Offline SnowSentry
    • WeatherWizz
« Reply #191 on: October 10, 2021, 01:08:24 AM »
It's a web page there is no reason why a web page would work on windows and not a mac.
Works on my Mac Mini.   I think your going to need to offer a lot more detail if you want to resolve your issue.
Cheers!
Offline captgadget
« Reply #192 on: October 17, 2021, 07:57:47 AM »
I follow the steps in Services with Meteobridge and where I'm supposed to paste the copied script is grayed out.
Offline SnowSentry
    • WeatherWizz
« Reply #193 on: October 18, 2021, 08:22:09 AM »
Sorry to hear your having problems with your meteobridge.  Perhaps post a question into the meteobridge forum.  I am sure the good folks over there will be happy to help or contact meteobridge support?
Offline SnowSentry
    • WeatherWizz
« Reply #194 on: January 02, 2022, 04:39:28 AM »
Hey there!
To kick off the new year, I'm excited to let you know that WeatherWizz custom dashboards now feature built-in pop-up charts.
Tap on just about any sensor for a quick snapshot of the day's weather trends. Easily see minimum and maximum values as well as the times these occurred.
If you're using a custom dashboard, simply refresh your dashboard to activate the charts and start tapping away!
Thank you for supporting WeatherWizz and happy new year!
www.weatherwizz.com
All the best
Duncan @ WeatherWizz
Offline Gyvate
« Reply #195 on: January 02, 2022, 05:16:48 AM »
Thanks for working on this and a Happy and Healthy New Year too !
However, since a few months now my dashboard only shows NaN values for all my extra temperature sensors.
Humidity and the rest is shown properly
Don't remember when it started ...  :-(
There was no change at my end
ew0001dt is the dashboard layout - station=FBDYSOLGQP
Offline SnowSentry
    • WeatherWizz
« Reply #196 on: January 02, 2022, 05:48:29 AM »
Hey Gyvate!
Thanks for letting me know.  the ew dashboards are pretty old now.  Let me see what I can do.  I'll contact you via email soon.
Offline SnowSentry
    • WeatherWizz
« Reply #197 on: January 02, 2022, 06:08:19 AM »
Just sent you and email :)
Offline waiukuweather
« Reply #198 on: January 02, 2022, 01:39:24 PM »
the graphing is a great addition !, kudos :)
Offline Gyvate
« Reply #199 on: January 03, 2022, 04:39:17 AM »
two more things:
1. why is the last lightning time stamp not showing as in your examples ?
It showed on the old ew dashboard and the data is still provided (CumulusMX) - only count and distance can be selected in the customizing dialogue.
2. the banner doesn't show most of the units while the dashboard does  :roll: - how to get the units also on the banner ?
