Author Topic: Common.php  (Read 591 times)
Offline n7xrd
    • Kamiah Weather
Common.php
« on: June 13, 2021, 06:48:21 PM »
So today I ran the check-fetch updater and updated all the files my page would only load halfway(no body) I dropped the "old" common.php file in and all works again as it should any ideas what might be causing this?
Offline gwwilk
  • Southeast Lincoln Weather
Re: Common.php
« Reply #1 on: June 13, 2021, 08:21:25 PM »
You surely have a customized 'common.php'.  Can you use a file compare utility such as 'CompareIt!' to bring your customization(s) into the new 'common.php'?  It will be a bit of a chore because you will need to keep Ken's latest modifications to 'common.php' while incorporating the mods from your old 'common.php'.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline n7xrd
    • Kamiah Weather
Re: Common.php
« Reply #2 on: June 13, 2021, 11:33:20 PM »
Good idea I will look at this tomorrow and see what I can find different. Thank you!
