Poll
Should everyone use official SI (Metric) or Imperial unit symbols?
Yes, everyone should use official SI (Metric) or Imperial symbols
No, it does not matter as other abbreviations are common
I don't care, I don't have an opinion. I just want to see the voting results.
Author Topic: Units and Symbols - Does it matter?  (Read 2395 times)
Offline K5GHS
    • K5GHS's Website
Re: Units and Symbols - Does it matter?
« Reply #25 on: February 27, 2020, 04:18:24 AM »
Normally I'd say one standard, but since a lot of sites allow you to display one or both....Just configure to show both, then both sides are happy.
I should note also that ones that don't oftentimes have either a configuration setting for the end user to set what they want to see, or a single button to show alternative units (MetOffice WeatherObservationsWebsite does this, I know).  So its not like you gotta whip out the ol slide rule because I'm running degrees F to get degrees C, you can usually specify it in your settings on the website (if you have a userid) and then if you click on my site it'll show you them in your "preferred" units anyway.
*tosses 2 cents into bucket*
Joshua
K5GHS
http://www.k5ghs.radio
Collin County, TX  Grid: EM13qd  CWOP: AV590
Skywarn Repeaters:  147.180 Primary 146.740 Secondary
100% Emergency Powered Ham Radio Station (540AH Batteries/Solar Rechargeable)
Ambient Weather WS-2000
Ecowitt GW1000
« Reply #26 on: February 27, 2020, 04:39:52 AM »
You are missing the point. This isn't a debate over Imperial vs. Metric. This is a debate of which symbol abbreviations are acceptable.
It is a debate between for example using; FT, ft, or Ft.
Or between; km/h, kph, kmph, or kmh.
...and the big question being, if there is a standard to follow from the governing agencies or if it doesn't matter?
I'm sure it doesn't help that some have gone off topic and are jokingly talking about Metric vs Imperial.
I've changed the poll to allow you to change your mind.
« Last Edit: February 27, 2020, 04:43:05 AM by galfert »
Offline Mattk
« Reply #27 on: February 27, 2020, 03:19:13 PM »
There has always been a "standard" saying .... The nice things about standards is there is so many of them
Offline the beteljuice
  • the beteljuice
    • test site
« Reply #28 on: February 27, 2020, 04:13:02 PM »
You've forgotten a 'new standard' ...
Making things machine readable !
[new line]
 eg. a crossed through zero would be interpreted as eight.[stop]
[end]
BTW (Is that allowed ?) I'm fed up of auto spell checkers telling me how the US do things ....
« Last Edit: February 27, 2020, 04:25:04 PM by the beteljuice »
Imagine what you will KNOW tomorrow !
« Reply #29 on: March 09, 2020, 11:42:41 AM »
This topic was triggered by the still beta new website for PWSweather. They originally used kph instead of km/h. I'm happy to report that PWSweather has responded to various people's feedback and they have removed all references to kph in favor of km/h.
 [tup]
