Author Topic: WS-80 Ultrasonic Anemometer/Multi Sensor Upgrade  (Read 2218 times)
Offline eliteweathernz
  • Weather Enthusiast/ Weather Equipment Support
« on: June 21, 2021, 03:19:29 AM »
Today I was informed my Jennie at Ecowitt that the reason my HP2553 was taking awhile to ship out was because the WS-80 Ultrasonic Anemometer/ MultiSensor was receiving an upgrade.
Likely the improvements mentioned in other threads around accuracy improvements.
Looking forward to receiving it in the next week or 2. According to Jennie it will be shipped out to me in New Zealand this Friday coming.
Has anyone else recieved a WS80 recently that may have the improvements added??
Offline Mandrake
Re: WS-80 Ultrasonic Anemometer/Multi Sensor Upgrade
« Reply #1 on: June 21, 2021, 04:31:14 AM »
I think you could be the first to see the improved model
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline giusCB
  • www.turismometeo.it
« Reply #2 on: June 21, 2021, 04:45:31 AM »
did they tell you the changes they made to the ws80?
www.turismometeo.it
Offline Jackpots
« Reply #3 on: June 21, 2021, 06:30:33 AM »
What I know is that, the newer model may/shall fixed water droplets which freezes the ultrasonic array sensors on very extremely rare occasions (especially storm with high winds or extremely high rainfall rate, like over 100-300mm/hr/s).
« Last Edit: June 21, 2021, 06:34:46 AM by Jackpots »
Current ECOWITT Sensors:
5x WN30
9x WH31
1x WH32
3x WH32B (1 Active)
2x WN34S
1x WN35
1x WH40
3x WH41
1x WH45 (Alpha "Pre Production" Test)
2x WH51
2x WH57
2x WS67/69
2x WS80 & 1x NEW WS80 (Revised Model)
1x WS90 Beta Testing
Equipment List:
Oregon Scientific THGR810 T&H Sensor (2010 - 2016)
Oregon Scientific BAR208HGA (2013 - )
FineOffset WH3081 (2015 - 2017)
AcuRite 02032 Pro (2016 - 2019)
ECOWITT HP2551 (2020 - )
ECOWITT HP2553 (2020 - )
ECOWITT GW1003 (2020 - ) - IBRISB722
ECOWITT GW1103 (2021 - )
« Reply #4 on: June 21, 2021, 09:00:06 AM »
Just in from Ecowitt ;)
HI, Trent
The main upgrade is done from two side:
1.      Metal net was changed to round type with underneath water flow tunnel added. This made the sensor robust to rain, and it will solve high wind speed read issue.
2.      We have a silicon rubber standing near the ultrasonic sensor, and this can guide the water to be bypassed rather than sitting on the sensor, which can lead to no data measurement problem at windy + heavy rain condition.
Here are the main changes done to this design. It will be a more stable design against Tempest or another competitor’s model.
Super glad they have made improvements, I guess I will report any findings when I receive it.
Sounds like a change in design to better manage water flow away from  the ultrasonic sensor.
I’ll post photos when it arrives and someone might be able to send a photo of there’s so we can compare the 2 designs.
Offline giusCB
« Reply #5 on: June 21, 2021, 10:11:57 AM »
ok perfect
www.turismometeo.it
Offline chaugen1
« Reply #6 on: June 21, 2021, 11:06:28 AM »
About to get a WS-5000 for my birthday around this weekend, I wonder if Ambient will offer this soon as well.
Offline sunnysideal
« Reply #7 on: June 21, 2021, 01:28:32 PM »
I have one of these after reporting issues with rain and dodgy readings, I've just not had the same conditions since it arrived to see how much it has improved things.
Offline giusCB
« Reply #8 on: June 21, 2021, 04:24:16 PM »
do you have some photos of the new ws80?
www.turismometeo.it
Offline sunnysideal
« Reply #9 on: June 21, 2021, 04:40:46 PM »
Hopefully not posted these twice! It's not in it's final position so I was able to run out and take these.
Offline giusCB
« Reply #10 on: June 22, 2021, 04:49:53 AM »
where's the improvements ?   :-k
I can see only small changes on the base
www.turismometeo.it
Offline sunnysideal
« Reply #11 on: June 22, 2021, 04:52:03 AM »
My understanding is that the issues are caused by water droplets interfering with the ultrasonic measurement, those changes should help remove droplets and fix the problem.
Offline giusCB
« Reply #12 on: June 22, 2021, 06:07:06 AM »
in previus message ecowitt says: "     2. We have a silicon rubber standing near the ultrasonic sensor, and this can guide the water to be bypassed rather than sitting on the sensor, which can lead to no data measurement problem at windy + heavy rain condition. "
i don't see anything of this    :-k
www.turismometeo.it
Offline sunnysideal
« Reply #13 on: June 22, 2021, 07:02:50 AM »
Possibly another change since I got mine, it'll be interesting to see the newest batch.
Offline Quagmire
« Reply #14 on: June 23, 2021, 11:07:57 PM »
Wouldn't the simplest fix for this be to just make the top half of the sensor array overhang the bottom by a fair amount?
« Reply #15 on: June 24, 2021, 01:10:48 AM »
I kind of thought about that too,
To kind of act as a deflector to any water that might get carried in by the wind.
Henry from Ecowitt said they have simulated intense rainfall and extreme wind conditions and they did not see any failure to read accurately or any spikes in the data following their modifications.
They tested in a wind tunnel by the sounds.
Offline Jackpots
« Reply #16 on: June 30, 2021, 07:06:20 AM »
I have received an email notice that my WS80CN has been shipped.
Not sure the reason it is called WS80CN, but I'm guessing it is the 433MHz version :shock:
5x WN30
9x WH31
1x WH32
3x WH32B (1 Active)
2x WN34S
1x WN35
1x WH40
3x WH41
2x WH51
2x WH57
2x WS67/69
Equipment List:
Offline giusCB
« Reply #17 on: July 01, 2021, 04:20:44 AM »
Remember to upload some photos  [tup]
www.turismometeo.it
Offline Mandrake
« Reply #18 on: July 02, 2021, 04:36:22 AM »
OK folks I have some pics here to show the updates courtesy of Henry in Ecowitt.
1.   We have under cuts on the plastic under the mesh nets. This leads to a better water discharge, and we have a round metal mesh net instead of the original bump up. So it looks better but more importantly it can have water sucked inside and drained much faster. This solved the problem for occasionally high wind speed measurement.
2.   The second change is from the up transducer side. We have a protection introduced so that no more water reaching to the sensor surface, and this solved the problem when at heavy rain time, the sensor stopped updating wind speed as the sensor was not in function with the water accumulated on the sensor.
G1ZFO
« Reply #19 on: July 02, 2021, 05:22:49 AM »
This is awesome Mandrakre!!
So far Henry has been super helpful and definitely has a technical background which makes finding out these little modifications all the more interesting.
Mine has just shipped from China so I should hopefully have it in the next week or so.
Looking forward to it.
Offline giusCB
« Reply #20 on: July 03, 2021, 06:25:11 AM »
I just ordered mine too, we'll see if it works as promised  8-)
www.turismometeo.it
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« Reply #21 on: July 03, 2021, 08:38:15 PM »
I am planning on buying one soon, but as I am in the US I am forced to buy through Ambient Weather.
I think I'll wait until their storeroom is refreshed before making the purchase.
Offline chaugen1
« Reply #22 on: July 03, 2021, 08:54:36 PM »
I got a WS-5000 on Thursday and I got the newer model.
Offline giusCB
« Reply #23 on: July 04, 2021, 05:12:33 AM »
i'm planning to install my new ws80 in a country near my city where raining much. So, we'll see if the problem is solved. I'll keep update this thread.  [tup]
www.turismometeo.it
Offline giusCB
« Reply #24 on: July 19, 2021, 11:41:55 AM »
any update from you ?
www.turismometeo.it
