Most of you know the data transmission problem I had during the month of Sept., therefore, I will not go into any of that other than to say that the new console, router and modem are all in sync and the data is transmitting perfectly. The new equipment has been in place for 11 days now and has not skipped a beat! The problem I am now having is with the CWOP analysis. I have been getting flagged every day indicating that my dewpoint reading is too low and they want me to increase it 2.7 to 3+ degrees. Since the dewpoint is a component of temp. and humidity, obviously the dewpoint reading cannot be calibrated by itself on the console. I checked with other stations in my area and found that I was pretty consistantly 2 degrees low (humidity) on average. So, I increased the humidity calibration in the console by 2 degrees a week ago. It is now pretty close to the other stations in my area (45 mile radius), but CWOP keeps posting the following message relative to the dewpoint analysis:
"There is a significant mean error in your dewpoint readings. You may need to calibrate your dewpoint sensor. Adjust your sensor to read 3.5 °F higher. Your readings are not within an acceptable error range"
I live at the south end (base) of a fairly shallow valley so my nighttime temps are always a couple of degrees cooler than alot of the areas here in Central Texas. In fact, most of the other reporting stations are located on a flat plains type terrain, while I am not. Additionally, the only two large airport stations are sited directly adjacent to large lakes, so I do not think their humidity readings are what I should compare to ( being Lake Waco and Lake Belton). I do not know what to do about this. Or is this something that I need to pay any further attention to? My temp. readings are on the mark (hot, damned hot, and too hot to do anything outside) and coincide with most other stations in my area as well during the daytime. I also do not know what to do about the humidity readings other than to take my entire unit to an airport for tech. analysis...which is not possible for me. I compared my humidity readings with 5-6 other stations early this morning and we were all detecting 20% humidity with a dewpoint of 42 degrees, but have not compared this afternoon's readings. Your input is always appreciated.
