Author Topic: Remote Access to MB Not Available?  (Read 745 times)
« on: November 10, 2019, 11:19:28 AM »
For several days now, no remote access to my MB.  It says to reboot, but it is 600 kms away.  The MB is still reporting though.  Ideas?
Re: Remote Access to MB Not Available?
« Reply #1 on: November 10, 2019, 11:39:51 AM »
My remote URL is working. Seems like GUI is locked up which I've seen happen on older firmware versions. In your situation when things are remote and they may need to be power cycled manually, I would invest in smart power plug adapters that you can control remotely.
« Reply #2 on: November 10, 2019, 12:49:49 PM »
Yeah, a smart plug for sure.  Next year.  :)  I used to have an RPi there and it could  cycle it locally, but that died and I never got around to replacing it.
Offline josecmorales
« Reply #3 on: December 09, 2019, 02:06:51 PM »
The same, until today 12/09 doesnt work.
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
« Reply #4 on: December 09, 2019, 02:11:45 PM »
I just tested remote login. It works. Same advice as before, restart your Meteobridge as it probably has a GUI freeze. If remote access is important and you can't manually power cycle then install a smart remote AC plug adapter.
Online Mattk
« Reply #5 on: December 09, 2019, 07:14:07 PM »
There was a server change 8/12/19, unsure if this could be affecting MB remote access?
Offline docbee
  • Moderator
    • smartbedded
« Reply #6 on: December 10, 2019, 07:17:07 PM »
Server change just affects the Meteoplug Cloud graphing service. Meteobridge itself is not impacted.
