Author Topic: IP-logger replaced with MB-NANO, continues upload to WeatherLink.com  (Read 901 times)
Offline wvdkuil
  • Wim van der kuil
My Davis IP-logger stopped working a few months ago and I replaced it with a far less expensive Meteobridge-Nano logger.
As a logger, the Nano has the same functionality as a Davis IP-logger including access for a weather-program to access through its ip address-port 22222.
I can now continue to upload to WeatherLink.com by using the DID and KEY from the sticker on the broken IP-logger.
But the Nano also has all the Metebridge-program functionality, including uploads to numerous weather-websites and it is supported by all website templates.
If your IP-logger ever fails you can have the exact functionality and a lot more for less money.
Wim
P.S.  Current prices in the Netherlands (including V.A.Tax):
Davis IP-logger on sale  280€, the Nano 195€  or the Nano-SD 260€
Offline superduty
Re: IP-logger replaced with MB-NANO, continues upload to WeatherLink.com
« Reply #1 on: October 24, 2019, 09:10:30 AM »
Is it correct that the standard meteobridge is unable to send data to Davis weatherlink?
Sent from my SM-G973U using Tapatalk
Offline wvdkuil
  • Wim van der kuil
« Reply #2 on: October 24, 2019, 09:19:13 AM »
All Meteobridges with an "attached" Davis station can upload to WeatherLink.com, but in most cases you need to have a logger also.
So in my case, a replacement for the broken IP-logger, it was less expensive to switch to the nano logger.
Wim
Offline superduty
« Reply #3 on: October 24, 2019, 09:37:09 AM »
With David logger installed, is it the Davis logger that's uploading to weather link or the MB?
Also does this require an attached computer running weatherlink software 24/7?
Offline wvdkuil
  • Wim van der kuil
« Reply #4 on: October 24, 2019, 09:57:04 AM »
The MB (from version 4.2)  is able to upload to the WL Cloud.  No PC needed.
Your USB/Serial logger can not do that on its own, never was able to do that.
Your WeatherLink PC-program could do that also, but you need the PC running 24/7.
Wim
Offline superduty
« Reply #5 on: October 24, 2019, 10:21:18 AM »
Wim
Is there a guide or instructions on how to do this?
Thank you
Offline wvdkuil
  • Wim van der kuil
« Reply #6 on: October 24, 2019, 02:05:21 PM »
. . . shortened . . .
Thank you
The Meteobridge forum announcement is here => https://forum.meteohub.de/viewtopic.php?f=56&t=14428
It works the same as uploads  to the other cloud companies.
Wim
Offline superduty
« Reply #7 on: October 24, 2019, 04:02:54 PM »
Thank you
Wim
Great. Thanks for the update.  Much appreciated.
