Weather Station Hardware => AcuRite Weather Stations => Topic started by: İbhlln on September 11, 2019, 04:09:55 AM
Title: Atlas thermometer connection socket
Post by: İbhlln on September 11, 2019, 04:09:55 AM
You can see Atlas's thermometer connection under the panel, too ?is it affected by rain?
Title: Re: Atlas thermometer connection socket
Post by: nincehelser on September 11, 2019, 08:58:47 AM
Is this what you are referring to inside the pagoda?
If so, it keeps it well shielded from rain.
Post by: İbhlln on September 11, 2019, 09:44:07 AM
Where the socket stays when you connect
How can I see your connection
Post by: nincehelser on September 11, 2019, 11:42:08 AM
That socket plugs into a jumper that runs to the circuit board in the electronics bay.
That socket is there so that you can easily service or replace the temp/humidity module if needed.
I don't have a picture of the jumper connection, but here is where it ultimately ends up in the electronics bay.  It's the connection labeled "TEMP."
Post by: İbhlln on September 11, 2019, 12:14:38 PM
Under padoga socket it looks wet from the rain
Padoga altındaki soket kavşağının yerini gördünüz mü
Just inside the shutters
Post by: nincehelser on September 11, 2019, 12:48:39 PM
I doubt that will be any issue.
The plastic connectors cover and separate the conductors pretty well.
