does the virtual usb to serial port show in windows device manager?
make sure weatherlink is set to serial mode
if you had set to usb mode, then the data logger is set to USX express mode, which is then like a HID USB port instead of a serial port
there is a utlility convertor program included with the weatherlink software installed programs that you can run to convert it back to virtual serial port
