Author Topic: WiFiLogger stops uploading CWOP data every morning  (Read 2658 times)
Offline 92merc
  • BismarckWeather.net
Re: WiFiLogger stops uploading CWOP data every morning
« Reply #25 on: January 18, 2021, 03:21:21 PM »
Maybe I got something wrong in the configuration ???? Can you tell me your steps?
I'm using my Cumulus to submit to Windy.  But under Setup, Data Export, It's on that page.
Offline BigAlT
« Reply #26 on: January 18, 2021, 06:26:01 PM »
I have a WFL1 and I have the Windy export settings window available on the Data Export Page of my WFL, located between the WOW export settings window and the CWOP export settings window.
V2.30 firmware.
Davis Vantage Vue ISS & Console with WiFi Logger 2
2nd Davis Vantage Vue Console with WiFi Logger 2
Davis Vantage Pro2 Console with Meteobridge Nano SD
Davis Weather Envoy with USB Logger connected to RPi 3B+ running WEEWX
WeatherFlow Smart Weather Station
Offline MatteoPV
« Reply #27 on: January 19, 2021, 12:55:49 PM »
V2.30 firmware.
I also have that window but once all the configuration is done, I never see my station online on Windy
Offline 92merc
« Reply #28 on: January 19, 2021, 01:23:13 PM »
After setting up my station here:
https://stations.windy.com/stations
I was able to click on it and see the data.
Offline MatteoPV
« Reply #29 on: January 19, 2021, 01:33:00 PM »
I had done it too but where do I get the 'station ID' entry?
Offline MatteoPV
« Reply #30 on: January 19, 2021, 01:45:51 PM »
I follow the page you recommended but then it tells me that I have no registered station. I do not understand
Offline 92merc
« Reply #31 on: January 19, 2021, 02:15:19 PM »
I've noticed that if I go to Windy.com directly, my station doesn't show.  But going through the Station link above, it does show a dot.
So honestly, I'm not sure why there is a difference.
Also, if you are a part of CWOP, Windy.com is already pulling your data from there.  So you may not need to send it at all.
« Reply #32 on: January 19, 2021, 03:28:15 PM »
If you only upload to CWOP then your station data on Windy will be much delayed ...up to 15 minutes (or possibly longer)...even if you are uploading to CWOP every 5 minutes. But if you upload directly to Windy then your data can be more timely at every 5 minutes.
Offline MatteoPV
« Reply #33 on: January 20, 2021, 06:26:20 AM »
Great information, thanks. I think I'll upload to both CWOP and Wundy if possible. Now I am uploading directly with the wifilogger to WL, WU and PWS Weather without any problems. For Windy, I'll be writing about their community.
thanks a lot
Offline MatteoPV
« Reply #34 on: January 21, 2021, 06:48:11 AM »
Sorry for the OT. I solved on Windy by creating a new account, it works. At the moment my wifilogger is uploading data simultaneously on:
Weatherlink
WeatherUnderground
Windy
Weathercloud
Awekas
CWOP
MetOffice
PWSWeather
All without problems
Offline davisuser1
« Reply #35 on: January 24, 2021, 04:12:20 PM »
I have been quiet on my WiFiLogger problem since late December, where I had concluded that WiFiLogger would reliably upload long term to CWOP as long as I did not have any other clients on my network receiving data from WiFiLogger. I was wrong. After a couple of more days the upload failed again. I have now resigned myself to have the CWOP upload being performed by the one PC on my network which is on 24/7. That has now been 100% reliable for more than 3 weeks. This is OK for now, but I am hoping for a firmware update for the WiFiLogger which will eliminate the need for a PC to do the upload. I do not think there is any problem with my local network.
Knut - AB2TC
