Author Topic: Anole weather sticker  (Read 2164 times)
« on: June 18, 2015, 08:27:23 AM »
Since my site has been moved to a different server, I was going to attempt the Anole server.
But I cannot get the files.  The link is dead.
http://scripts.anolecomputer.com/download.shtml
Any way else I can get it?
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
Re: Anole weather sticker
« Reply #1 on: June 18, 2015, 09:25:22 AM »
That topic came up recently, and this post has the script http://www.wxforum.net/index.php?topic=26204.msg252621#msg252621.
- Jim
« Reply #2 on: July 01, 2015, 03:11:35 PM »
Got it going.  FINALLY!  I am not sure if it would have worked on the old server.
But its working.
Just cant figure out how to change the background.
The district is also FINALLY figuring out how to put it on the school webpage.
« Last Edit: July 02, 2015, 08:23:22 AM by chief-david »
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #3 on: July 02, 2015, 11:37:07 AM »
You should have a file called "banner_big" just replace that with whatever you want, just make sure you keep it the same size.
Software: WeatherDisplay
« Reply #4 on: July 02, 2015, 12:19:50 PM »
did it with one
http://weather.rms.rdale.org/WDL2/wxgraphic.php?type=banner
Paint!!  I can work on a background pic later
Thanks-another challenge.  I should have it all done by the time I retire.
« Last Edit: July 02, 2015, 12:21:31 PM by chief-david »
« Reply #5 on: July 02, 2015, 03:53:49 PM »
Finally did it. Only took 6 years
http://weather.rms.rdale.org/banners.php
« Reply #6 on: November 10, 2020, 10:48:41 PM »
Back at it. New version
I copied everything from my old site. Weather stickers not working.
Please check
http://www.bsmweather.org/wxgraphic/config.txt
http://www.bsmweather.org/wxgraphic/PHP_verify.php
http://www.bsmweather.org/wxgraphic/wxgraphic.php
« Reply #7 on: November 11, 2020, 12:31:11 AM »
Looks like you have
Parse error: syntax error, unexpected 'Wind' (T_STRING), expecting ')' in /home/bsmweather/www/www/wxgraphic/config.txt on line 280
You'll need to copy wxgraphic.php to wxgraphic.txt and post it for us to debug further.
« Reply #8 on: November 11, 2020, 10:56:05 AM »
http://www.bsmweather.org/wxgraphic/wxgraphic.txt
What bugs me is I copied all of the files from the old school and put them in and they do not work.
« Last Edit: November 11, 2020, 12:54:08 PM by chief-david »
« Reply #9 on: November 11, 2020, 01:17:45 PM »
It's line 256 in config.txt
imagecenteredtext(75, 145, "bsmweather.org, 2, 7, $color6, 0); it's missing the closing double-quote
imagecenteredtext(75, 145, "bsmweather.org", 2, 7, $color6, 0);
« Reply #10 on: November 11, 2020, 01:29:31 PM »
that is it. Thanks.
I goofed that one up.
I will work on colors now.
And to get them to show on the other banners
http://www.bsmweather.org/wxgraphic/banner_big.gif
« Last Edit: November 11, 2020, 01:41:28 PM by chief-david »
« Reply #11 on: November 15, 2020, 10:26:19 AM »
no luck on other banners. confuzzled.
« Reply #13 on: November 15, 2020, 02:48:10 PM »
They seem to be working:
http://www.bsmweather.org/wxgraphic/wxgraphic.php?type=banner
http://www.bsmweather.org/wxgraphic/wxgraphic.php?type=banner_big
The only one not working is
http://www.bsmweather.org/wxgraphic/wxgraphic.php?type=sig which is missing sig.gif as a background on your site.
So that was my fault. did not use the correct address. Sometimes----- ](*,)
I forget things when I only mess with them once every 5 years. (or more)
Thanks. Now on to the main site again.
