Author Topic: WiFi Logger 2.0 for Davis Vantage  (Read 2334 times)
Offline onedart
« on: May 20, 2020, 03:40:09 PM »
Hello
Recently purchased a Wi-Fi Logger 2.0 from Pro Data, I’m trying to export my data to Wunderground, all details filled in on the relevant data export screen though when I go to Wunderground the station is always offline, anybody have any ideas.
Offline PaulMy
Re: WiFi Logger 2.0 for Davis Vantage
« Reply #1 on: May 20, 2020, 04:14:39 PM »
I presume in all other functions the WiFiLogger is working OK?  and are you doing any other uploads?
Are you using the correct station ID (not mistaken O for 0 or I for l)?
Enjoy,
Offline WiFiLogger
« Reply #2 on: May 20, 2020, 04:15:53 PM »
Some time ago it was needed to use ID and Password, but password was the same which you are using while loging to WU.
Now you need to use ID and KEY which you have with station info.
After that you should wait some time like 15,30,45 minutes, first batches of data after station creation are not accepted by WU.
You can switch on RAPIDFIRE to check if this will make any difference.
Offline onedart
« Reply #3 on: May 21, 2020, 06:37:59 AM »
Thanks for advice, online now
Offline BrianLehan
    • Grace C Lehan Memorial Weather Station
« Reply #4 on: June 10, 2020, 04:10:49 AM »
Onedart - What did you have to do to get it on-line with WU?
Brian
Davis Vantage Pro 2 plus
VWS 15x on Windows 7
Sarasota-Weather Template
Gr3 Radar
Offline WiFiLogger
« Reply #5 on: June 10, 2020, 04:29:57 AM »
Brian
Just put ID and KEY (not pass to WU account).
Set interval like 3 minutes, or enable RapidFire.
Click save and wait about 15-30 minutes.
Offline BrianLehan
« Reply #6 on: June 10, 2020, 12:33:10 PM »
Guess I'm not sure what the WU KEY is?
I have a WU api key from WU is that what you have to enter if I switch over to wifi logging?
Gr3 Radar
