Weather Station Hardware > WiFiLogger/Meteo-Pi
RPi 4B MeteoPI and Davis Vantage Pro 2 Not Passing Data
(1/1)
KK7GO:
Greetings,
I have search this forum unsuccessfully to find a solution to my issue. If I missed a post, please provide link.
I upgraded to a RPi 4B, using Twister OS. I am also using WeeWx. My weather station is a Davis Vantage Pro2. The MeteoPi is the data logger. I boot the RPi via USB
I am not seeing the ttyUSB0 serial connecting. I have enabled the UART.
I thought the weewx.conf file is correct, but I may have missed something.
Any information links or ideas are appreciated.
Thanks for the help.
Ron
WiFiLogger:
Did you set Serial like on screen shot?
rcnz:
Hi.
Similar issue.
I'd been using WeeWX with Davis logger.
I bought my WFL and Meteo-Pi together.
WFL has been working perfectly. [tup]
I replaced it with My M-P, set the interfaces per Wojtek's screenshot, but am not seeing any output from M-P.
I'm hoping to resume using WeeWX, but need some guidance re output ports/methods, etc, please.
Robin..
johnd:
Which serial port have you tried? ttyS0 or ttyS1? Or both?
rcnz:
Thanks, johnd.
I was struggling to get this sorted.
I ran wee_config --reconfigure and chose ttyS0
Then I pasted previous station data into the clean 4.5.1 weewx.conf
Problem solved!
Two days of pain fixed
=D>
