Author Topic: Atlas temp/humidity sensor tear-down  (Read 766 times)
Offline jteloh
« on: March 14, 2021, 04:48:06 PM »
To start you should review the excellent thread by nincehelser https://www.wxforum.net/index.php?topic=35220.0
I started this troubleshooting session when my sensor started to eat batteries. As I poked around I discovered the easy to remove temp/hunidity sensor. When I removed it it became clear why things were not working right. One circuit of four was totally bad.
I used a PH00 screw driver to remove the housing top
Offline jteloh
Re: Atlas temp/humidity sensor tear-down
« Reply #1 on: March 14, 2021, 04:50:26 PM »
I know the red wire is broken. It broke man handling the sensor out.
Offline worachj
  • Twin Cities, Minnesota
« Reply #3 on: March 15, 2021, 10:37:22 AM »
Nice to know they now have a replacement temp/humidity sensor for the Atlas! Thanks for posting the link.
AcuRite Atlas
KMNSAINT173
Offline daman
« Reply #4 on: March 16, 2021, 10:02:03 AM »
That's a tell tale sign the temp/hum is going south, my 5n1 did that, after replacing the thermo board all is well and going on 3 years with this last set of batts.
KMIBADAX38
AcuRite Iris/AcuRite Access
