Author Topic: New Atlas ISS not showing up on WU  (Read 576 times)
Offline jjh92
« on: March 08, 2021, 11:31:00 AM »
I swapped my Acurite Atlas ISS for a new one.  Previous ISS was running on WU just fine.  I configured the new ISS with identical WU key as old ISS.  It's registered and showing just fine in MyAcurite but it is not showing online on WU.  It's been 2-days since the swap.  How long should it take to show up on WU?  Any secret to changing the ISS on my WU account that's causing it to not show?
Offline worachj
  • Twin Cities, Minnesota
Re: New Atlas ISS not showing up on WU
« Reply #1 on: March 08, 2021, 03:48:13 PM »
Just a guess ... MyAcuRite.com maybe hanging onto the old Atlas device ID. If you haven't already tried this I would go on MyAcuRite.com and under the Share Weather menu remove the old "Share to Weather Underground" entry and recreate it to pick up the new Atlas and its device ID.
« Last Edit: March 08, 2021, 03:50:35 PM by worachj »
AcuRite Atlas
KMNSAINT173
Offline jjh92
« Reply #2 on: March 29, 2021, 01:47:32 PM »
No luck with deleting an recreating the WU Share on MyAcurite.  When I look at the Access splash page, there is a field for WunderGround Device.  What goes in this field?
Offline worachj
« Reply #3 on: March 29, 2021, 03:40:48 PM »
Its your device ID as listed on WU under your My profile/My device screen. Ex. mine is KMNSAINT173.
AcuRite Atlas
KMNSAINT173
Offline jjh92
« Reply #4 on: March 29, 2021, 03:45:15 PM »
I'm referring to the Wunderground Device blank field.
Offline worachj
« Reply #5 on: March 29, 2021, 03:52:30 PM »
I believe that field gets filled in by MyAcurite.com when you set up your new Atlas to send to WU under the Share Weather menu.
Edit: You need to use the app or www.myacurite.com to set it up.
« Last Edit: March 29, 2021, 03:55:15 PM by worachj »
AcuRite Atlas
KMNSAINT173
