Author Topic: How to water proof outdoor cables  (Read 1105 times)
Offline captgadget
« on: January 23, 2021, 10:27:27 AM »
So I finally got this camera running but now I have these cables exposed to all the weather elements of South Texas minus snow. Anyone have any suggestions on how one might waterproof these cables?
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: How to water proof outdoor cables
« Reply #1 on: January 23, 2021, 11:34:23 AM »
That connector set up is a drawback of this camera.
For mine I drilled a hole in the barge board and passed the whole thing inside under cover. I put an access panel in the vented soffit right underneath to access the reset button.
« Reply #4 on: January 23, 2021, 12:39:01 PM »
I have a bigger box at school for the rain gauge heater etc.
https://bsmweather.org/pictures.php
and a few of the plug covers around the house for running christmas lights.
« Reply #5 on: January 23, 2021, 01:51:39 PM »
Another solution is to mount the camera on the underside, upside down, where you see previous screw holes. The camera interface should let you flip the image. Then the cable connection should reach to not be exposed. These cameras are designed to be flush mounted where the connectors are inside of the building.
« Reply #6 on: January 23, 2021, 06:43:19 PM »
   ^^i did that with an old Foscam
It is snowing now, should not have any issues with it.
Offline josecmorales
« Reply #7 on: January 25, 2021, 09:23:38 AM »
I think yor best option is or a junction box or the boxs saying by chief-david.
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
Offline TinkerTown
« Reply #8 on: February 12, 2021, 08:36:25 AM »
Get something like https://amzn.to/3d8bOh4 and then mount it to your awning. Then mount the camera to it, and stuff your cables inside. They will be protected from the elements in the waterproof junction box, just like you would electrical wires. You can drill a tiny hole on the bottoms to allow condensation to dribble out, should it accumulate due to temperature changes.
« Last Edit: February 12, 2021, 08:39:11 AM by TinkerTown »
Ecowitt GW1000 | WS-2902C |Weewx on Raspberry Pi
WU: KNMLOVIN14  |  PWSweather: PWSLOVNM1
CWOP: FW9112; https://lovingtonweather.com
