Author Topic: AcuRite 6045M Lightning Detector not working on 5-in-1.  (Read 853 times)
Offline JacobRhyne
    • Personal Weather Station Dashboard
« on: June 10, 2021, 10:40:42 AM »
Our AcuRite 6045M lightning detector that came with the AcuRite 5-in-1 Weather Station is not working. No lightning strikes, no lightning distance, nothing. Tried removing the sensor from the AcuRite 6088M display and inserting it again, it still won’t show the green light on the sensor even with the batteries in. The batteries are fine, but the lightning detector is still not working. What are the causes of the lightning detector not working and how can we fix it?
AcuRite 6088M 5-in-1 Weather Station with Lightning Detector
Link to PWS Dashboard:
https://www.wunderground.com/dashboard/pws/KNCCONNE47
Weather Underground KNCCONNE47
Offline daman
Re: AcuRite 6045M Lightning Detector not working on 5-in-1.
« Reply #1 on: June 10, 2021, 11:15:20 AM »
IS it still under warranty? contact AcuRite
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline JacobRhyne
« Reply #2 on: June 10, 2021, 01:46:24 PM »
I do not know if it is under warranty or not.
Offline worachj
  • Twin Cities, Minnesota
« Reply #3 on: June 10, 2021, 05:09:50 PM »
Did you try selecting a different channel (A,B,C). There's a switch inside of the lightning detector. And make sure the display is looking for the same channel setting.
AcuRite Atlas
KMNSAINT173
Offline JacobRhyne
« Reply #4 on: June 10, 2021, 05:11:42 PM »
I will try selecting a different channel tonight or tomorrow, and see if it fixes the problem.
