Author Topic: max temp for WN30 sensor  (Read 326 times)
Offline Autofill
« on: October 06, 2022, 02:12:43 PM »
hi, the max temperature for the WN30 is listed as +60oC
https://www.ecowitt.com/shop/goodsDetail/104
its a bit suspicious because its the same as the other sensors that don't have the external probe, so i suspect that temperature max includes the body of the sensor?
I'm using this for a clothes dryer automation where I'm placing just the probe in the exhaust heat pipe. I don't know how hot it will get, but only the probe will be exposed to such temperatures.
« Last Edit: October 06, 2022, 02:17:39 PM by Autofill »
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline Gyvate
Re: max temp for WN30 sensor
« Reply #1 on: October 06, 2022, 03:33:57 PM »
or, the probe just contains the same temperature sensor type as the WH31.
You'll have to find out by experiment I guess ...
Offline olicat
    • FOSHKplugin
« Reply #2 on: October 06, 2022, 06:20:56 PM »
Hi!
The WN30 has a 60°C cut off. Means: the max temperature measured (and displayed and sent) is 60°C.
Oliver
Offline Autofill
« Reply #3 on: October 18, 2022, 02:27:37 PM »
thanks, all for your answers.
Indeed 60oC is the max but, its fine for me as I'm using for an automation (in Home Assistant) that tells me when my dryer in done drying the clothes. Usually when it drops below 45oC, it stops drying.
 I haven't measured it, but I think my dryer can go as high as 85oC but will likely be around 65oC for most times.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
